Title: Megadrum USB-Midi adapter PIC18F2550 Post by: slack on July 27, 2012, 11:19:33 23:19 I am planning to make USB-Midi adapter so I can use my old Roland synth with my PC.
I found very interesting Megadrum project and I thought to rip the USB-Midi part from schematics and make a standalone USB-Midi device. I will design PCB and post it here when i make it. But before I make it, I would like to hear some experiences about USB-Midi part of Megadrum if somebody has already made it and uses it. Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: motox on July 28, 2012, 11:26:06 11:26 If you just need an USB-MIDI converter then it’s cheaper to buy a cable converter from eBay.
They are very cheap, starting at $4 inc. postage. Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: slack on July 28, 2012, 12:00:36 12:00 Thank you.
I know, but I heard that cheap USB-MIDI adapters from ebay don't work with Win7. Is that true. Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: motox on July 28, 2012, 12:50:34 12:50 That’s not true. I have one cheap Chinese cable and it works under Win7 64bit.
Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: metal on July 28, 2012, 01:26:15 13:26 i tried to download the source code for megadrum, but could not find it, any one knows where?
Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: slack on July 28, 2012, 02:05:30 14:05 If you think of source code for USB-Midi part of Megadrum, the only source I found is this one (for PIC18F2550).
Title: Re: Megadrum USB-Midi adapter PIC18F2550 Post by: metal on July 28, 2012, 02:56:05 14:56 my bad, I meant atmega codes :- ) I should have mentioned that earlier.
thanks any way |
