Title: 2 way intercom Post by: kumar on March 04, 2020, 11:20:52 11:20 Dear members,
Those who wants a simple 2 way intercom with normal telephones with dialling and ringing facility this simple project comes from a reputed magazine along with pcb design too.... Title: Re: 2 way intercom Post by: enzine on March 05, 2020, 08:46:51 20:46 :-[
From your pdf : "TWO-WAY PC-FAX INTERFACE" "This circuit imitates a small telephone exchange, allowing a PC to dial a fax machine, and vice versa, without actually making use of the public telephone network. Very useful if you want to employ your fax as a scanner (switch it to high resolution!), or as a 200-odd dpi printer. For these applications, it is assumed that you have a fax card in your PC. The software supplied with this card will then enable you to convert scanned images into the widely used TIFF format. The circuit shown here is suitable for pulse dialling only. Fortunately, that is still supported by most fax machines and PC fax cards." ?!? Ciao Title: Re: 2 way intercom Post by: kumar on March 05, 2020, 10:00:41 22:00 I already made this circuit many times and works without fail.
Simply connect two normal telephone or wall mounted telephone with K2 & K3 terminal. Title: Re: 2 way intercom Post by: h0nk on March 05, 2020, 10:09:20 22:09 Hello, simply replace the fax machine and the fax card with two old phones and You are near the solution. My old Zyxel U-1496E doesnt like the 50/60 Hz anyway. It needs the real 25 Hz of an old german rington. Best Regards Title: Re: 2 way intercom Post by: token0 on March 15, 2020, 05:03:55 17:03 Also if you have DECT base with two or more handsets: most of models have "int" button, that's the built-in intercom. Cheap and efficient.
