Title: Sine Look UP Table Post by: king on May 25, 2009, 09:17:04 09:17 Hi!
The code provided by the microchip for 3 Phase Induction motor control ,in this code they are using Sine look up, but from the code I don't understand that how they are taking the values for 3 phase which are 120 degree apart from each other from single Sine Look Up table which is from 270 degree to 90 degree with 10 Degree Resolution. They are using the 3 offset pointer for 3 phases but what is the method of taking 3 values with the help of offset register which are 120 degree apart from each other from single SIN look up Table. Please explain me if anybody read this code from application note "AN889". Any kind of help will be highly appreciated. Regards KING Title: Re: Sine Look UP Table Post by: LabBoy on May 26, 2009, 03:22:44 03:22 I am not sure that I understood your question, and also I haven't read the AN889.
I think you mean that how to look up a sine-table for 3-phase sine wave, am I right? If YES, this is my suggestion, For 10 degrees resolution of 1-cycle (0-360 degree) of sine wave, the sine-table can be generate from 36 points data as the code belows: Code: #define res 10 // 10-degree resulution Code: p1[i] = st[i]; // 0 degree The Demo of this algorithm can be downloaded at http://www.hotshare.net/file/143979-353940116c.html (http://www.hotshare.net/file/143979-353940116c.html) It was written by my friend (Santi Nuratch, Thailand). If you need more details, you can contact me directly. Regards, LB. Title: Re: Sine Look UP Table Post by: king on May 28, 2009, 11:13:56 11:13 Hi!
Yes I really mean that how to look up a sine-table for 3-phase by the help of 19 values of Sin which starts from 270 degree and ends at 90 degree with 10 degree resolution. ;******************************************************************************* ;EQUATION USED FOR CALCULATION OF SINE TABLE ENTRIES = (SIN(ANGLE)+1)*FF/2 ;ANGLES ARE FROM 270 DEG. TO 90 DEG. STEP SIZE = 10 DEG. ;******************************************************************************* Sine Table: RETLW 0X00 RETLW 0X01 RETLW 0X07 RETLW 0X11 RETLW 0X1D RETLW 0X2D RETLW 0X3F RETLW 0X53 RETLW 0X69 RETLW 0X7F RETLW 0X95 RETLW 0XAB RETLW 0XBF RETLW 0XD1 RETLW 0XE1 RETLW 0XED RETLW 0XF7 RETLW 0XFD RETLW 0XFF Please explain me the method of taking "Set of 3 values of Sine" at a time, from the table given above, which are 120 Degree apart from each other without using trigonometric Sin function. Posted on: May 28, 2009, 12:08:10 12:08 - Automerged Hi! These are the codes of 3 Phase induction Motor and they are using Sine Look Up table for taking "3 sin values" which are 120 degree apart from each other. Please have a look at this. Regards King Title: Re: Sine Look UP Table Post by: sohel on May 28, 2009, 06:57:03 18:57 ??? ::)
;******************************************************************************* ;EQUATION USED FOR CALCULATION OF SINE TABLE ENTRIES = (SIN(ANGLE)+1)*FF/2 ;Sine table has value corresponding to every 10 electrical degrees ;******************************************************************************* TABLE SINE_TABLE addwf PCL,F RETLW .2 RETLW .4 RETLW .8 RETLW .16 RETLW .24 RETLW .34 RETLW .50 RETLW .64 RETLW .80 RETLW .96 RETLW .112 RETLW .128 RETLW .144 RETLW .156 RETLW .168 RETLW .178 RETLW .184 RETLW .188 RETLW .190 ;******************************************************************************* ;THIS ROUTINE INITIALIZES THE PARAMETERS REQUIRED FOR MOTOR INITIALIZATION. ;******************************************************************************* INIT_MOTOR_PARAMETERS #ifdef PSC_MOTOR_CONTROL movlw 0x012 ;INITIALIZE THE TABLE OFFSET TO 3 REGISTERS movwf TABLE_OFFSET1 ;TO FORM 0-120-240 DEGREES movlw 0x00 movwf TABLE_OFFSET2 movlw 0x08 movwf TABLE_OFFSET3 bcf FLAGS,OFFSET1_FLAG ;OFFSET FLAGS INITIALIZATION bsf FLAGS,OFFSET2_FLAG btfsc FLAGS1,FWD_REV goto INIT_MOT_REV bsf FLAGS,OFFSET3_FLAG ;Offset3 initialized goto INIT_MOT_FREQ INIT_MOT_REV bcf FLAGS,OFFSET3_FLAG #endif #ifdef THREE_PHASE_MOTOR_CONTROL movlw 0x09 ;Initialize the table offset to 3 registers movwf TABLE_OFFSET1 ;to form 0-120-240 degrees bsf FLAGS,OFFSET1_FLAG ;Offset flags initialization btfsc FLAGS1,FWD_REV goto INIT_MOT_REV movlw 0x03 movwf TABLE_OFFSET2 bcf FLAGS,OFFSET2_FLAG movlw 0x0F movwf TABLE_OFFSET3 bcf FLAGS,OFFSET3_FLAG goto INIT_MOT_FREQ INIT_MOT_REV movlw 0x0F movwf TABLE_OFFSET2 bcf FLAGS,OFFSET2_FLAG movlw 0x03 movwf TABLE_OFFSET3 bcf FLAGS,OFFSET3_FLAG #endif INIT_MOT_FREQ movlw 0xB1 movwf TMR0 bsf FLAGS,MOTOR_FREQ_COUNTER RETURN Title: Re: Sine Look UP Table Post by: santi_inc on May 29, 2009, 11:00:28 11:00 Hello Everybody,
I posted the new version of the 3-Phase Sine wave Generator/Simulator at http://www.sonsivri.com/forum/index.php?topic=22872.0 Regards, santi_inc |
