Title: Installing Drivers in Windows 8.x Post by: #tester on June 14, 2014, 01:36:28 13:36 While installing drivers in Windows 7 is not a problem Windows 8 can be challenging.
Try this for when you need to install drivers: Invoke the Charms bar and click on Settings. Open control panel by clicking on "Change PC Settings”. In Windows 8: Select "General” and then "Advanced Startup” In Windows 8.1: Select "Update and Recovery” and then "Recovery” Click "Restart now". Now the system will restart and might take some minutes to show up the boot menu. Wait for It patiently. After some time you will be prompted with a menu with following options: - Continue - Troubleshoot - Turn off Choose "Troubleshoot". Then the following menu appears: - Refresh your PC - Reset your PC - Advanced Options Choose "Advanced Options". Then the following menu appears: - System Restore - System Image Recovery - Automatic Repair - Command Prompt - Windows Startup settings Choose "Windows Startup Settings", then Click Restart. Now the computer will restart and the boot menu appears. Choose “Disable Driver signature Enforcement” from the menu. Now windows will start and you can install the driver. |
