Title: [REQ] IMAGE TO G-CODE patch needed Post by: bader357 on January 09, 2013, 09:34:08 09:34 Has anybody a keygen, patch or serial for this Software?
Description Image to Go Code imports most digital image files into G-Code format that can be ran with most computer numerical control routers and mills. The software package includes: A basic digital image editor to allow you to retouch the image before send it to the g-code converter. The converter reads the pixels information directly from imported image and creates the g-code file. Before the g-code file is created the size of the carving dimensions and the maximum tool depth can be increased or decrease without the need to reprocess the image. Image resolution can also be adjusted using several methods like the k-factor, axis combine, reverse, close enough and the x and y axis resolution. Prep-code and post-code can be edited with the G-Code Editor built into the application for easy access and more. Image to G-Code can convert raster images to vectors also. Image to G-Code also imports DXF files from most CAD programs. (AutoCAD release 12 compatible), the importer support most geometric entities including inserts [with nested blocks]. After the DXF file is imported all supported entities are put in list organized by layers. The G-Code setup options form allows you to set layer level priorities including turning on and off the layer, set the tool release plane, close enough, default Z-Axis character, pre-code and post-code, optimize, and more. Image to G-Code also includes a little CAD drawing editor that allows you to modify imported DXF-Files, convert True Type Fonts to vectors, and draw lines, circles, polygons, arcs and more. The built in G-Code editor is a text editor with the basic find and replaced functions, clipboard support, undo and redo, math expression parser, triangle and distance between two points calculators and G-Code M-Code panel that includes most G and M codes formatted syntax including circular interpolation calculations. Image to G-Code is a fully integrated for easy interaction and its graphic user interface is similar to most Microsoft Windows© applications found in the market today. (http://) Download Demo Software http://www.imagetogcode.com/Download.htm (http://www.imagetogcode.com/Download.htm) Homepage http://www.imagetogcode.com/ (http://www.imagetogcode.com/) |
