Title: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: mars01 on October 23, 2017, 08:48:27 20:48 SketchUp Pro 2017 17.2.2555 (x64)
Mega, Zippy and Uploadfiles.io links Title: Re: SketchUp Pro 2019 (x64) Post by: pickit2 on September 15, 2019, 09:23:35 09:23 SketchUp Pro 2019
MegaLink Install and update two part install see readme.txt Title: Re: SketchUp Pro 2017 - 2019 (x64) All Versions Post by: mars01 on March 06, 2020, 07:33:00 19:33 SketchUp Pro 2020 20.0.362 x64
What's new: https://help.sketchup.com/en/current-release-notes Features: • create, document and make a presentation of the project using one single drawing. • Draw, modify, measure, rotate, scale, and move geometric shapes. • The location and annotation of many scaled images on one page • Buildings, furniture, interiors, building structures and much more are designed in a matter of minutes. • Export of 3D models to CAD and other 3D formats • Export of 2D vector images • Model shadows in real time for any area on Earth. • Creating multi-page documents and presentations • Creating customizable presentation elements and notation using 2D vector tools • Creating rendering effects in the form of sketches and fog, signing models using 3D text, emblems and watermarks • Matching existing models to background images • Getting professional email support • Use exact dimensions and indicate them using text. • Set section planes for viewing and working inside models. • Use prepared textures in models, such as brick, wood, tile, glass, or create new textures. • Add pre-built components, such as trees, cars, doors and windows, as well as people, or create new components. • Smooth surfaces. • Simulate the location of the camera in space. • Use organic modeling (using the Sandbox). • Import two-dimensional images (.jpg, .png, .tif, .tga, .bmp) and three-dimensional models (.3ds, .dem, .ddf, .dwg, .dxf, .skp). • Exporting 2D images of models - JPEG (.jpg), png, tif, tga, bmp • Placing SketchUp models on Google Earth is performed using the Place Model command. Exporting a Google Earth file directly to the KMZ format. • Model sharing in the 3D model service. • You can print part of the model displayed in the drawing area of SketchUp. • Print and export bitmaps at the selected resolution. • Export animations and passes to MOV or AVI files. • Export to 2D formats: PDF, EPS, Epix (.epx), AutoCAD (dwg, dxf) • Export of 3D models to formats: 3DS, AutoCAD (dwg, dxf), fbx, obj, xsi, vrml ******************************************************** Attached MEGA, Zippyshare, Filedropper links with a RuTracker torrent. LE: Added in the attached file a MEGA link with the actual software files and fix. Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: pickit2 on July 19, 2020, 10:33:41 22:33 SketchUp Pro 2020 20.0.373 x64
SketchUp Pro 2020 version 20.1.235 64-bit Posted on: March 08, 2020, 11:27:51 23:27 - Automerged Update new post is silent install Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: Unhappy on September 25, 2020, 08:49:38 08:49 SketchUp Pro 2020 20.0.373 x64 Kindly provide with another link preferrably with mega as the site is blocked in my countrySketchUp Pro 2020 version 20.1.235 64-bit Posted on: March 08, 2020, 11:27:51 23:27 - Automerged Update new post is silent install TIA UnHappy Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: Manuel on September 25, 2020, 09:13:32 09:13 Try using TOR BROWSER.
take care, X! Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: Unhappy on September 25, 2020, 09:53:20 09:53 Try using TOR BROWSER. Already tried but of no use :otake care, X! Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: Sideshow Bob on September 25, 2020, 12:29:47 12:29 Already tried but of no use :o I can download a torrent for you and post it here version SketchUp Pro 2020 v20.2.172 and or SketchUp Pro 2020 v20.1.235 both with patch or crack Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: pickit2 on September 25, 2020, 01:29:47 13:29 SketchUp 2020.2.172
Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions Post by: Sideshow Bob on September 26, 2020, 05:35:27 17:35 Kindly provide with another link preferrably with mega as the site is blocked in my country What you could try is to use a public DNS server, as the blocking perhaps is done by DNS level at your ISP. I use both Google and CloudFlare to get around blocking. It is at least worth a try. But I do not know if it will work for youTIA UnHappy https://medium.com/@nykolas.z/dns-resolvers-performance-compared-cloudflare-x-google-x-quad9-x-opendns-149e803734e5 Title: SketchUp Pro 2021 x64 added Post by: pickit2 on December 05, 2020, 04:25:54 16:25 New SketchUp 2021
Please stop posting links to other sites. See new link Title: Re: SketchUp Pro 2021 x64 added Post by: Unhappy on December 19, 2020, 11:40:03 11:40 New SketchUp 2021 Kindly provide fresh D/l as File(s) deleted by megaSee link Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on December 19, 2020, 03:01:46 15:01 New Link
Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: Wilksey on March 01, 2021, 10:12:51 10:12 Hi Pickit2,
Would you mind uploading the link again the last one seems to have disappeared too... Many Thanks Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on March 01, 2021, 12:00:05 12:00 Hi Pickit2, yes way too many Mega links that are posted here are being reposted in other sites. we have some nasty users in here. that's for sure.Would you mind uploading the link again the last one seems to have disappeared too... Many Thanks Mega & filefactory links. Title: SketchUp Pro 2020 (x64) Post by: pickit2 on August 09, 2022, 05:10:41 17:10 SketchUpProFull-2022 x64
1. run original install file 2. Update (silent Patch) Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: fantomex on August 27, 2022, 02:07:59 14:07 any infos on how to use after running the silent update patch?
application still asks for license Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on August 28, 2022, 01:29:15 01:29 did you install to x86 or some other folder. ? it needs to install to default folder. c:\Program Files\SketchUp 2022\
Silent update will write to this location. Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: chandra2sekhar2000 on October 10, 2022, 10:36:54 10:36 Hi,
installed to below location C:\Program Files\SketchUp 2022 tried to run the update patch, when opened, still application asking for signin / add classic licence asking for licence serial numbers. any help to fix this issue.thank you Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on October 10, 2022, 03:21:04 15:21 I did not keep the files, but from memory when you run the install just press enter "it will install to the default folder" then run patch/update and it will patch the 3 files. you can run install and patch from desktop no need to copy to install folder.
just a note SketchUp.exe will have a modified date later than the installed files. If the same date the patch did not run as it should have done. Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: PM3295 on October 10, 2022, 03:40:16 15:40 Hi, installed to below location C:\Program Files\SketchUp 2022 tried to run the update patch, when opened, still application asking for signin / add classic licence asking for licence serial numbers. any help to fix this issue.thank you I had the same problem. I then used the old patcher released with 2021 version, it worked for me. Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on October 10, 2022, 08:05:48 20:05 I had the same problem. I then used the old patcher released with 2021 version, it worked for me. So how it that helping as there are no working links in this topic, unless you already have it in your mega vault. Posted on: October 10, 2022, 07:59:36 19:59 - Automerged Warning Do not post links to other sites. Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: chandra2sekhar2000 on October 11, 2022, 09:45:11 09:45 Hi,
any links for the working patch. thank you Title: Re: SketchUp Pro 2017 - 2020 (x64) All Versions 2021 added Post by: pickit2 on October 11, 2022, 10:30:14 10:30 Hi, here are the files you need - replace the installed with these.any links for the working patch. thank you link fixed. Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: pickit2 on March 14, 2023, 12:07:36 12:07 Sketch Up Pro Studio (x64)
Install and Update (x64) file size 1.88Gb Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: Old_but_Alive on March 14, 2023, 01:45:47 13:45 too big to download from filefactory.
could some kind soul place it on mega.nz please Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: pickit2 on March 14, 2023, 08:07:00 20:07 too big to download from filefactory. see readme download the demo. I don't like demo & crack as files can change. could some kind soul place it on mega.nz please Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: Gorgus on March 15, 2023, 09:13:33 09:13 Mirrors at TurboBit, NitroFlare and Mega.nz
Thank pickit2, not me. Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: pickit2 on September 09, 2023, 04:16:58 16:16 Sketch Up new single silent install.
I had to reinstall Sketch Up so repacked it. smaller size file. Posted on: September 06, 2023, 12:03:08 12:03 - Automerged SketchUp Pro 2023 v23.1.315 Updated link 9/9/2023 Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: Marcustv on September 10, 2023, 07:32:31 07:32 SketchUp Pro 2023 v23.1.315 Updated link 9/9/2023 Perfect, works very well Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: pickit2 on October 07, 2023, 02:01:51 14:01 Sketch Up Pro Studio (ver 23.1.329.64)
Install and Replace Files (x64 Only) Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: UncleBog on January 04, 2024, 12:36:47 12:36 Quote Sketch Up Pro Studio (ver 23.1.329.64) Install and Replace Files (x64 Only) This is no longer available at the link provided, could someone upload it again please ? Title: Re: SketchUp Pro & SketchUpStudio (x64) All Versions2023 added Post by: pickit2 on January 04, 2024, 03:43:59 15:43 updated to latest version.
Version 23.1.340 64-bit |
