Title: Arial 868mhz layout in proteus Post by: David_1 on July 19, 2017, 04:42:14 04:42 hi all been messing with hope rf rfm69hcw radio transceivers but I am looking for a pcb Arial design drawn with proteus ?
if you have something that fits the bill it would help me out RF is not my strong point.. Thanks David edit from here :- http://www.ti.com/lit/an/swra227e/swra227e.pdf I made this(its not finished yet) Posted on: July 18, 2017, 09:45:39 21:45 - Automerged file Title: Re: Arial 868mhz layout in proteus Post by: witsanukai on July 24, 2017, 03:20:48 03:20 if you need to implement antenna layout base on TI document i though you can refer to page 4 for each lenght and dimension, draw in proteus by 2D graphic box mode to your expect dimension then fill solid by double clik or polygonal SMT pad mode to draw also can, sorry cause i cannot open your rar (don't know file type) so cannot help much.
Title: Re: Arial 868mhz layout in proteus Post by: pickit2 on July 24, 2017, 09:36:55 09:36 You need to build your PCB Arial as fig 1.
it is then added to your main pcb, as a module or part of the main board. in you proteus layout the main problem is you have no board edges. |
