Title: Replacement SLA7024 circuit Post by: elcielo on August 22, 2023, 01:12:28 13:12 Hi all
How I change SLA7024 ? Plz help me. Title: Re: Replacement SLA7024 circuit Post by: Checksum8 on August 22, 2023, 05:28:42 17:28 Are you asking where to find replacement parts? Or how to unsolder and replace the parts?
I googled SLA7024 and PSL136MR, both parts are avaliable to buy. To remove the SLA7024. Cut each lead close to the IC, leave long enough to hold with needle nose pliers. Heat each pin and pull out with pliers. Then with solder wick or a solder sucker clean the solder from the pcb. Put new part in and connect to heatsink before soldering. The other part is only 8 pins so use solder wick or sucker Title: Re: Replacement SLA7024 circuit Post by: elcielo on November 30, 2023, 03:58:56 03:58 Internal Block Diagram
(http://) |
