Title: picall crack needed Post by: arash on November 30, 2005, 04:05:57 04:05 Hi.
I want to use picall or p16pro programmers but It is limited. where can i find the keygen or 16f628 firmwar (just for picall)? Thanks Title: picall crack needed Post by: bayramonur on November 30, 2005, 10:31:56 10:31 Which version?Picall version 0.16 is free.
Quote PICALLW software version 0.16 January 2005 FREEWARE (http://inxm.net/zip/paw016.zip)What is new? (http://inxm.net/txt/newbeta.txt) And I use Winpic800.(My programmer Pic16Pro Kit 96) Title: Re: picall crack needed Post by: alsabbag on December 25, 2007, 09:59:59 21:59 I have Picall hardware purchase three years ago. The Software Picall or Picallw is available for free download but I don't think that the firmware is published and the chip comes protected when you purchase the programmer.
Title: Re: picall crack needed Post by: zawmintun1 on August 21, 2008, 08:22:41 08:22 Hi
Please Upload again its gone Title: Re: picall crack needed Post by: johnri on August 28, 2008, 02:54:31 02:54 go to this website: http://picallw.feniks-pro.com/
PICALLW software version 0.16 is free now, and the author is also giving away the source code in return for a small donation. EDIT: go here for the source code: http://home.icequake.net/~nemesis/src/picallw/ Title: Re: picall crack needed Post by: borberk on August 29, 2008, 08:42:15 08:42 here is picall v018 which is available from Bojan Dobaj for small amount
http://rapidshare.com/files/140982895/picall-018.rar Title: Re: picall crack needed Post by: johnri on September 05, 2008, 11:14:16 11:14 Here is the source code package for the version v0.18 (v018)
http://rapidshare.com/files/142788059/picallw_source.rar.html password: Sonsivri Title: Re: picall crack needed Post by: dideco on September 05, 2008, 05:55:34 17:55 Hi,
There is a reset pin setup in the software for p16pro mode. Is there a reset hardware in the kit or circuit? Is there anyone have information about reset hardware in the programmer? I often had trouble with this software after programming anf if programming pins were programmed as outputs. Software can program an erased chip but cannot find hardware after programming. But the other software can simply erase and program same chip with the same hardware. |
