Title: Sothink DHTML Menu 8.2 Build 71113 Post by: okarli on November 19, 2007, 12:11:27 12:11 (http://pixhost.eu/avaxhome/avaxhome/2007-11-17/screenshot1jz9.jpg)
hxxp://rapidshare.com/files/70772736/SDM.8.2.71113_home.zip Sothink DHTML Menu 8.2 Build 71113 | 6.5 MB Sothink DHTML Menu is the most popular JavaScript drop down menu maker currently found on the web. It covers all your DHTML web menu system needs and more. With our brand-new intuitive user interface, it easily creates fully featured cross-browser drop down menus in a visual edit mode. You can generate stylish DHTML menus in minutes with our frequently updated templates. Resource Folder settings and big optimized publishing guide you to add a drop down menu to your pages in a fast and easy way without any hand coding, working both locally and on the web. Free Dreamweaver, FrontPage, Expression Web and GoLive add-ins help you quickly design your menu and integrate it with your existing web site. Sothink DHTML Menu Builder also generates search-engine-friendly drop down web menus, which therefore can be properly indexed by search engines, such as Google. Optimization * Brand-new interface has improved the fashionable skin, the reasonable layout and handy editing * Full Edit Mode enables to edit and preview menu in the preview window directly; double-click menu item to edit its text in preview window; the modification can be synchronized between preview window and Menu Tree panel * Set Resource Folder for resources files to make the same menu display exactly in multi-page of different folders; and preview the menu locally or on the web * Simplify Publishing to insert the menu into the page easier; auto-generate menu code; copy and paste resource files used in the menu into the specific folder * Add new templates, modify the present style in the built-in templates and re-arrange the existing templates New * Keyboard Navigation function enables user to control the menu by using the keyboard. Press Alt + F2 to enter. * Disable certain items and separators function can hide certain items or separators due to your own needs. * Multi-column Menu can arrange long pop up menu items in a table in group; and the multi-row menu can also be reached * Copy and Paste function duplicates menu items quickly and keep their properties in the same or different program windows * Supports switching to drop-down menu from tree-like menu by importing the authoring file (*.stm) of Sothink Tree Menu * Adds new special effect – Rectangle, which is supported by all compatible browsers * Tips of the Day provides tips & tricks about using the program * Encoding can encode menu in the proper language * Supports W3C Valid XHTML 1.0 Valid XHTML 1.0 Features * Full cross browser compatibility (Immediate coverage of browser updates) ( IE 7 and FireFox 2 included!) * Dreamweaver, FrontPage, Expression Web and Adobe GoLive integrated plug-ins totally for FREE * Database driven JavaScript menus with server-side code, like ASP, PHP, JSP, ASP.NET or ColdFusion * Generates search engine friendly drop down menus * Free Google XML Sitemap and general sitemap generators based on your menu structure * Generates a drop down menu structure from your existing web site pages by our unique Site Navigation Generator * Visible over Flash, selected boxes, Iframes and even PDF files * Position menus anywhere on your web page easily * Creates cross frame menus for all kinds of frame-based web site, like common frames, nested frames or Iframes * The current page in use can be auto-highlighted in your DHTML menu navigation * Auto scrolls long pop up menu items * Float menus follow the browsers’ scrollbars * Context right click menu; use any elements on your page to trigger the menus, such as image, text, or even a Flash movie (Custom menu) * Supports Non-English languages, even Right-to-Left languages, such as Arabic * Fully customizable properties, like font, icon, background, border, cursor, tool tip, surround, effects, alignment, transparency, size and etc,. * Select images for icon, arrow, background and separator easily from our rich Image Library * Multiple menus on the same page; multiple pages use the same JavaScript menu * Any HTML code can be used within menu items * Free combination of vertical or horizontal sub menu items * Menus can span 100% across the width of your web page; each menu item of the top level will be auto adjusted to get even width * Supports any doctypes, and supports UTF-8 |
