Title: 100W (or more) Vac dummy load Post by: M@X77 on November 27, 2019, 05:03:31 17:03 Hi to everyone, I need to test some transformers, I would like to avoid to use a rheostat, but a dummy Vac load.
Someone did had the same question? Found a solution? I tried to search but I didn't get any results. In google I found the attached schematic, but it don't convince myself. It seems strange where the potentiometer get ref (r3 on load input), I think it need a voltage reference if I want costant current load. thanks Massimo Title: Re: 100W (or more) Vac dummy load Post by: LabVIEWguru on November 28, 2019, 01:25:24 01:25 What about a 100 W incandescent lamp? Title: Re: 100W (or more) Vac dummy load Post by: forter on November 28, 2019, 06:12:03 06:12 Hi, M@X77! If done as shown in the diagram, it turns out that the conductivity will depend on the input voltage. And this means non-linearity of resistance. Title: Re: 100W (or more) Vac dummy load Post by: M@X77 on November 28, 2019, 04:16:41 16:16 What about a 100 W incandescent lamp? I would like a costant current load to do AC transfonformer experiance @forter: it's my own thought, if so, just use a reference voltage, no? Title: Re: 100W (or more) Vac dummy load Post by: kreutz on November 28, 2019, 04:34:20 16:34 I have used a water filled bucket and water heater heating elements in the past.
Title: Re: 100W (or more) Vac dummy load Post by: Checksum8 on November 28, 2019, 04:41:07 16:41 Years ago, I did transformer testing using a dc constant current load with a 25 amp bridge rectifier between the two. I don't remember the details, like if a electrolytic capacitor was needed on the load side?
Title: Re: 100W (or more) Vac dummy load Post by: forter on November 29, 2019, 06:42:15 06:42 @M@X77 I think the idea of Checksum8 of using a bridge rectifier is a very interesting solution. Only, of course, without any capacitor and of course R3 must be connect to a constant reference voltage
Title: Re: 100W (or more) Vac dummy load Post by: flyback on November 30, 2019, 11:26:04 11:26 I found this link. Seems that's more or less what you sought (an AC constant current load).
https://electronics.stackexchange.com/questions/218976/ac-constant-current-source-design/219747 Title: Re: 100W (or more) Vac dummy load Post by: bobcat1 on December 01, 2019, 07:57:29 07:57 Hi
Both circuit are simple to simulate in LTSpice or Pspice just to know whether they work or not - you don't have to use same components just choose close parameters. All the best Bobi Title: Re: 100W (or more) Vac dummy load Post by: solutions on December 01, 2019, 02:14:53 14:14 What exactly are you testing on these transformers...and why?
Title: Re: 100W (or more) Vac dummy load Post by: M@X77 on December 02, 2019, 10:06:24 10:06 What exactly are you testing on these transformers...and why? I need to test nominal current and check temperature, the problem was the current is different and I need flexibility. --------- I think to use a classic DC mosfet dummy load and put a Graetz Bridge without capacitor, the current tha flow in the circuit is equal, the mosfet "sees" DC pulse current but this I think is not a problem. Title: Re: 100W (or more) Vac dummy load Post by: Sideshow Bob on December 02, 2019, 12:49:55 12:49 By the way. You are aware that regarding current ratings. They are in AC. If you load your transformer with a typical setting with a rectifier and filter (inductor/capacitor) The DC current you should allow for. In some cases should be much lower than the transformer AC current rating.
Just in case this something new for you I leave this Google link for you https://www.google.com/search?q=Design+Guide+for+Rectifier+Use (https://www.google.com/search?q=Design+Guide+for+Rectifier+Use) Title: Re: 100W (or more) Vac dummy load Post by: Checksum8 on December 02, 2019, 05:28:55 17:28 I would use a clamp on AC current meter or current transformer to get actual readings from the transformer. Don't rely on some pulsed DC on the load side.
Title: Re: 100W (or more) Vac dummy load Post by: titi on December 02, 2019, 05:59:05 17:59 Hi,
In Elektor Labs there is an article about an Electronic load for DC and AC. May be it can helps. They use an DC Electronic Load behind a bridge rectifier for AC mode. https://www.elektormagazine.fr/labs/electronic-load-for-dc-and-ac (https://www.elektormagazine.fr/labs/electronic-load-for-dc-and-ac) The video https://www.youtube.com/watch?v=YXUa-xOSNLE&t= (https://www.youtube.com/watch?v=YXUa-xOSNLE&t=) In attachemnt all the files of the project. Best regards. Title: Re: 100W (or more) Vac dummy load Post by: M@X77 on February 26, 2020, 11:42:29 11:42 Hi, In Elektor Labs there is an article about an Electronic load for DC and AC. May be it can helps. They use an DC Electronic Load behind a bridge rectifier for AC mode. https://www.elektormagazine.fr/labs/electronic-load-for-dc-and-ac (https://www.elektormagazine.fr/labs/electronic-load-for-dc-and-ac) The video https://www.youtube.com/watch?v=YXUa-xOSNLE&t= (https://www.youtube.com/watch?v=YXUa-xOSNLE&t=) In attachemnt all the files of the project. Best regards. Very interesting! thanks I trying to do |
