Title: GTP-USB Lite Post by: greywolf on November 22, 2007, 09:35:26 21:35 The schematic for the GTP-USB Lite programmer calls for
a 12mhz. crystal. Does anyone know if this can be replaced with a 16mhz. crystal . If so, what other changes need to be made. Regards, Title: Re: GTP-USB Lite Post by: telfo2007 on November 22, 2007, 10:58:01 22:58 It seems that gtp firmware clock configuration and timing is based on external 12MHz. Changing clock frequency would make not to be detected by USB PC hardware (not right timing).
Title: Re: GTP-USB Lite Post by: GreenGiant on November 23, 2007, 10:12:57 10:12 16mhz is not possible, see the datasheet for the PIC to determine what speeds are possible.
Normally, its a multiple of 6mhz, as the PLL can create a frequency from almost any multiple of 6mhz, and then it gets divided to 24mhz for the USB coms. Title: Re: GTP-USB Lite Post by: Ahmad_k on November 23, 2007, 11:36:04 11:36 Stop Posting about GTP-USB programer there is a lot of post in this forum please read before posting, or reply in existing post.
I ask moderator to close this topic |
