Title: Using OSA RTOS? Post by: devfirat on May 14, 2011, 11:11:15 23:11 Nowadays i want to work on RTOS. Lots of people suggest OSA RTOS. I read instruduction and examples but i didnt built one program yet.
Can you help me in these questions? First, where will unrar to RTOS files? Second, i'm using C18, do you send me one example? Third, i prefer MPLAB X, but i also use MPLAB old version. I use 18F2520 Thanks.. Title: Re: Using OSA RTOS? Post by: 5dads on May 15, 2011, 06:23:27 06:23 Just open and compile the example files that come in the OSA RTOS download. Every one I have tried compiled without error, and the few that I have tried in hardware worked as documented.
Once you have one of their examples working, you can start modifying it for your own desires. Title: Re: Using OSA RTOS? Post by: devfirat on May 15, 2011, 08:39:56 08:39 Just open and compile the example files that come in the OSA RTOS download. Every one I have tried compiled without error, and the few that I have tried in hardware worked as documented. Once you have one of their examples working, you can start modifying it for your own desires. I know that but, can you show me my questions' answers step by step?? Because i dont understand where do i unrar the files? I always get an error. I cant try example because of that. Title: Re: Using OSA RTOS? Post by: devfirat on May 16, 2011, 01:40:38 01:40 Solved!
http://www.youtube.com/watch?v=5Y9nkQ1x0yI Title: Re: Using OSA RTOS? Post by: sughoi on May 16, 2011, 03:34:37 03:34 Dear devfirat,
could you please upload your source code? best regards, sughoi Title: Re: Using OSA RTOS? Post by: devfirat on May 17, 2011, 12:40:13 00:40 You can look at here: http://www.fxdev.org/rtosa-giris-osa-rtos/
You can translate it to English. Title: Re: Using OSA RTOS? Post by: sughoi on May 17, 2011, 06:39:37 06:39 Dear devfirat
Thank you very much for the article. I will use OSA instead of FreeRTOS. By the way Turkish is OK no need to translate in to English. best regards, sughoi Title: Re: Using OSA RTOS? Post by: devfirat on May 17, 2011, 05:13:40 17:13 Everyone, works with RTOS, tells me to use FreeRTOS.
I'm new at this but i can tell OSA is good for beginning. ;) Title: Re: Using OSA RTOS? Post by: sughoi on May 17, 2011, 08:14:00 20:14 Dear devfirat
I'm also new in RTOS field and I know that the worse thing at RTOSs is configurations. It takes a lot of time but once you understand it, it becomes so east to use. Best regards, sughoi Title: Re: Using OSA RTOS? Post by: devfirat on May 17, 2011, 09:51:45 21:51 I'm confusing about using small delay.
If I want 30us delay, or something like that. What should I do about it? I always use ADC or LCD and like that. And I must always use delay function. Can I combine this delay functions with RTOS? I know about RTOS tick and how to use it. I dont mean that. Title: Re: Using OSA RTOS? Post by: sughoi on May 18, 2011, 08:06:25 08:06 It is also a problem for me. If you ask my opinion may be you can prefer CCS compiler and its RTOS. Also you can find a book that gives a few clear example of CCS RTOS. The book is below;
Dogan Ibrahim - Advanced PIC Microcontroller Projects in C: From USB to RTOS with the PIC 18F Series http://www.4shared.com/document/OZyhKrds/Advanced_PIC_Microcontroller_P.htm?aff=7637829 Best Regards, sughoi Title: Re: Using OSA RTOS? Post by: devfirat on May 21, 2011, 03:38:39 15:38 I don't like and prefer his books. Thanks by the way.
Some people tells me use C++ if you want to work on RTOS professionally. Title: Re: Using OSA RTOS? Post by: sughoi on May 21, 2011, 06:30:20 18:30 dear, devfirat
If you want to choose C++ than go ahead. but I know that small size microcontrollers are a good target for C++. so it seems to me that you want to focus on powerful processors. Anyway, please inform time to time. Also it can be a good work of study for me. best regards, sughoi Title: Re: Using OSA RTOS? Post by: robban on June 06, 2011, 08:29:53 20:29 I use a 18F97J60 running at 40MHz. I'm experimenting with Pragmatec PIC18OS (open source) and the latency time is 50us but interrupt time is 1 ms, managed by an internal RTC.
You can use these defines: /* MAGIC : Tmr0.lt = 65536 - (CPU_FREQUENCY_HZ/4/1000 - 232) */ #define _10MHZ 63320 #define _16MHZ 61768 #define _20MHZ 60768 #define _32MHZ 57768 #define _40MHZ 55768 It should be placed in Yr Interrupt.c file (if You have any!) Have a look in Yr. datasheet for INTCONbits.TMR0IF or whatever it's called for Yr. PIC. There you also have alternative timer settings Try it... Title: Re: Using OSA RTOS? Post by: devfirat on March 06, 2012, 09:10:05 21:10 This RTOS works very good with Atmel AVR microcontrollers ;)
