May 18, 2025, 07:39:39 19:39
Top
HI-TECH Universal RSA Keygen
* HI-TECH Universal RSA Keygen generates real RSA signed activation data.
* Replaces HI-TECH RSA public key with self-generated RSA key - different every time!
* Generates permanent PRO key - no expiry date!
* Tested with:
  • HI-TECH C Compiler for PIC10-12-16 MCUs
  • HI-TECH C PRO for the PIC18 MCU Family
  • HI-TECH C PRO for the PIC32 MCU Family
  • HI-TECH for dsPIC-PIC24
  • HI-TECH C PRO for the Silicon Labs 8051 MCU Family
  • HI-TECH C PRO for the PSoC Mixed-Signal Array
  • HI-TECH C for Holtek MCU
  • HI-TECH PICC-18 STD
* New in version 2.2
* New in version 2.3
HI-TECH Universal RSA Keygen (v2.0)
http://depositfiles.com/files/kj9mws7yh
HI-TECH Universal RSA Keygen (v2.1)
http://depositfiles.com/files/oy699bhti
HI-TECH Universal RSA Keygen (v2.2)
http://depositfiles.com/files/2mhscdmb4
HI-TECH Universal RSA Keygen (v2.3)
http://depositfiles.com/files/v6vup2azq
You can find 50caliber post here, the older sticky:
http://www.sonsivri.com/forum/index.php?topic=935.msg69111#msg69111
« Last Edit: June 24, 2010, 01:52:07 13:52 by Top »
Pages: 1 ... 8 9 10 11 12 13 14 [15] 16 17 18 19
Author Topic: Hi-Tech PIC Compiler latest versions  (Read 595890 times)
cjq_sh
« Reply #350 on: May 19, 2010, 03:03:20 15:03 »
I tested CLEAN.BAT and v2.2x64.
Then it works well in pro mode.
Thank you very much TOP !!!
« Last Edit: May 19, 2010, 04:05:53 16:05 by cjq_sh » Logged
Top
-Given: 53
-Receive: 1719
« Reply #351 on: May 19, 2010, 04:02:17 16:02 »
Problem was due to virtualization in Vista & Windows 7. Activation data written to registry by older keygen is written to VirtualStore and takes precedence over newer global data written by HI-TECH Universal RSA Keygen. Solution is to delete HI-TECH data from VirtualStore, CLEAN.BAT included in HI-TECH Universal RSA Keygen v2.2 deletes this data.
http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630
-Receive: 991
« Reply #352 on: June 03, 2010, 12:59:13 12:59 »
Hi Caliber,
HI-TECH PICC PRO 9.70.rar (5.53 MB)   http://www.multiupload.com/AE7BMBILM7
is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO.
Please help if anybody try this software. thanks.
Is is a small problem with the crack method in the HI-TECH PICC PRO 9.70.rar (5.53 MB). If you are using a non English windows version.
You have to open open the "picc.reg" and check if the
"InstDir"="C:\\Program Files\\HI-TECH Software\\PICC\\9.70"
is correct for your non English windows version. If not you have to correct it. I guess this will also apply to the other versions of HI_TECH compiler. If you are in doubt use the method found here http://www.sonsivri.com/forum/index.php?topic=935.msg97630#msg97630.
By the way! Keep up the very good work both bunions and 50caliber
juabba
« Reply #353 on: June 09, 2010, 06:21:19 18:21 »
HI-TEC PIC18C + WIN 7   does not work
I changed from a XP to a WIN 7 PC
installed fresh MPLAB +  HI-TECH 9.70  for PIC 10/12/16  that is offered as an option on the MPLAB installation.
During the installation, I let installer to modify the PATH.
Additionally I installed HCPIC18-pro-9.64.5502, also updating the PATH.
For testing porpoises (because the hi-tech is not working) I also installed the MCC18 trial downloaded from microchip site.
As a result I have MPLAB working 100% with   MCC18, compiling, simulating, etc, but when I try to use any HI-TECH compiler, no luck
main symptoms ( when using the “Project wizard” to generate a new project using hi-tech )  are:
1>on step two “select a language toolsuite” the HI_TECH Tool suite does not appear.
    If “show all installed toolsuites” is selected, it shows as “active toolsuite” the HI_TECH universal tool suite, but if I use browse to select the “C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe, the “store tool location in project” CAN NOT BE SELECTED, IS gray.
2>After finishing to define the new project with the wizard (including a main.c as a source file), if we go to project-->build options-->project I noticed following
    a> the main.c included as source program do not appear on the little window, only “project” appears as an option
    b> selecting the project option, if we go to the “diver” tab, the drivers list is totally empty, as if no hi-tech suite were installed.
I don't think is an installation problem.
 Of course I removed and installed all over again at lest once to verify if any installation problem did occur
pls help
jjose
Posted on: June 09, 2010, 07:02:10 19:02 - Automerged
pls help
jjose
I have following additional information
for the PIC18 MCU Family  V9.63PL3 ( loaded also for testing )
"C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18" --ver
HI-TECH C PRO for the PIC18 MCU Family  V9.63PL3
Copyright (C) 1984-2009 HI-TECH SOFTWARE
licensed for evaluation purposes only
this licence will expire on Fri, 30 Jul 2010
looking at registry
HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63
Activation  “long series of binary values”
expiry         Fri, july 30,2010
license         evaluation only
serialNo      HCPIC18P-DEMO
Top
-Given: 53
-Receive: 1719
« Reply #354 on: June 09, 2010, 07:43:31 19:43 »
It seems like your HCPIC18 is not getting detected by MPLAB.
HCPIC18-pro-9.64.5502 is a release candidate, uninstall it and install HCPIC18-pro-9.63PL3.
This is normal if you have chosen a PIC18 processor and MPLAB does not recognise your HCPIC18 installation. When you select 'Show all installed toolsuites' it is showing your PIC 10/12/16 compiler. 'Store tool locations in project' checkbox for the HI-TECH Universal Toolsuite is not used.
a) I don't understand you.
b) Have you got the 'Show XXXXX drivers only' box ticked?
I think it is Smiley
HI-TECH and Windows 7 does work. See previous posts/screenshots.
-Receive: 991
« Reply #355 on: June 09, 2010, 08:16:47 20:16 »
Have you used the keygen in the sticky? That is the most easy one to get working. I am now using the both the 18 series and the 10/12/16 series C compiler from Hi-Tech. You could also try the clean.bat found in the sticky keygen, and then do a reinstall
« Last Edit: June 09, 2010, 08:21:56 20:21 by Sideshow Bob » Logged
juabba
« Reply #356 on: June 10, 2010, 03:17:01 15:17 »
actually I am testing with Hi-Tech compilers downloaded from  microchip ( 45 days evaluation copies) , so there is no keygen need.
looking at registry at
HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC / PRO / 9.70
or
HKEY_LOCAL_MACHINE / SOFTWARE / HI-TECH Software / PICC-18 / PRO / 9.63
I verified the programs are 100% validated.
jjose
Top
-Given: 53
-Receive: 1719
« Reply #357 on: June 10, 2010, 04:08:20 16:08 »
or
jjose
If you have used any HI-TECH patches or keygens on this machine before then clean out any HI-TECH data from the VirtualStore and check the "InstDir" string in the following keys is correct.
Windows 7 (32-bit)
HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63\PL0
HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC\PRO\9.70\PL0
Windows 7 (64-bit)
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HI-TECH Software\PICC-18\PRO\9.63\PL0
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HI-TECH Software\PICC\PRO\9.70\PL0
juabba
« Reply #358 on: June 10, 2010, 04:47:43 16:47 »
Hi Top
looking at registry at :
InsDir =   C:\Program Files\HI-TECH Software\PICC\9.70
and on
HKEY_LOCAL_MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.63\PL3
InsDir =    C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63
it looks correct, is it?Huh
thanks for help
jjose
Top
-Given: 53
-Receive: 1719
« Reply #359 on: June 10, 2010, 04:58:05 16:58 »
and on
This looks OK but do you have any HI-TECH Software keys in:
HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE
juabba
« Reply #360 on: June 10, 2010, 05:16:09 17:16 »
I think you got it    Grin
there is one left over
HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE\HI-TECH Software\PICC-18\PRO\9.64\PL0
MPIndex = 00001
should I clean it???
thanks again
jjose
Top
-Given: 53
-Receive: 1719
« Reply #361 on: June 10, 2010, 05:34:47 17:34 »
MPIndex = 00001
Maybe not your problem but delete that key and check this folder for HI-TECH Software:
%LOCALAPPDATA%\VirtualStore\Program Files
juabba
« Reply #362 on: June 10, 2010, 06:00:06 18:00 »
Top
marvelous.     Shocked Shocked
thanks a lot.
cleaned the two of them and 9.70 compiled ok
latter will check the others
jjose
juabba
« Reply #363 on: June 10, 2010, 07:51:03 19:51 »
when tested the 9.63 original, it reported no drivers.
in order to gain time, I used the CLEAN.BAT from the HI-TECHv2.2.rar package, and now 9.70 as well as 9,63 official versions are working ok on windows 7.
now I wonder if installing the HCPIC18-pro-9.64.5502 package from this site on the windows 7 machine will function.
thanks a lot to all
jjose
juabba
« Reply #364 on: June 22, 2010, 02:32:19 14:32 »
I found a bug on the plib of PICC-18\PRO\9.64.
Is not difficult to fix. ( have reported to microchip and they approved it)
testing HI-TECH Software\PICC-18\PRO\9.64, you get an error  on the
HI-TECH Software\PICC-18\PRO\9.64\include\peripheral\usart.h
when your source program use the UART  (USART_Status), you get
Error   [499] ; 0. undefined symbol:
        _USART_Status(xxxx.obj)
the problem is the lack of local definition of following union:
union USART
  unsigned char val;
  struct
    unsigned RX_NINE:1;         // Receive Bit 8 if 9-bit mode is enabled
    unsigned TX_NINE:1;         // Transmit Bit 8 if 9-bit mode is enabled
    unsigned FRAME_ERROR:1;     // Framing Error for USART
    unsigned OVERRUN_ERROR:1;   // Overrun Error for USART
    unsigned fill:4;
extern union USART USART_Status;
as you can see, it has the “extern” keyword at the beginning of last line above.
Just removing the extern fix the problem
( you'll find same problem on 3 places of   “PRO\9.64\include\peripheral\usart.h”)
extern union USART1 USART1_Status;
extern union USART2 USART2_Status;
juabba
Top
-Given: 53
-Receive: 1719
« Reply #365 on: June 24, 2010, 01:49:24 13:49 »
HI-TECH C Compiler for PIC10-12-16 MCUs V9.71a
http://depositfiles.com/files/mzw39xyxw
* New release (24-jun-2010)
HI-TECH Universal RSA Keygen v2.3
cddx
-Given: 27
« Reply #366 on: July 01, 2010, 01:57:07 01:57 »
union USART
  unsigned char val;
  struct
    unsigned fill:4;
juabba
union USART
  unsigned char val;
  struct
    unsigned fill:4;
juabba
it's not a bug! since you have only declaration
Manuel
-Given: 712
-Receive: 194
« Reply #367 on: July 03, 2010, 10:44:59 10:44 »
Something I got reading on Mchip site related to Compiler...
Note: Version 9.71a is intended for midrange devices only. Baseline support is limited at this time and will be fully supported in version 9.72
take care u all!
kipkip
-Receive: 16
« Reply #368 on: July 06, 2010, 08:18:43 08:18 »
Mirror D/L link -->    HI-TECHv2.3.rar
http://ifile.it/phbe5ng
dientuso
« Reply #369 on: July 20, 2010, 06:04:15 18:04 »
HI-TECH Universal RSA Keygen for LINUX
* Tested on Ubuntu Linux 9.04 with:
  • HI-TECH for dsPIC/PIC24
  • HI-TECH C Compiler for PIC10/12/16 MCUs
  • HI-TECH PICC-18 STD COMPILER
HI-TECH Universal RSA Keygen for LINUX (v1.0)
http://depositfiles.com/files/f25aamcnr
Anyone tested on Karmic(Ubuntu 10.04) It fail on Karmic with message:
Activatation error : Invalid serial number
Exit status 161
anybody can help me???
Top
-Given: 53
-Receive: 1719
« Reply #370 on: July 20, 2010, 07:04:36 19:04 »
Exit status 161
Look in the README; this is normal on Linux as there is no option for off-line activation. You now need to run the keygen and then the 'activate' command with the keyfile.dat.
Also, note that the Linux Keygen (v1.0) has not been tested with v9.71a.
« Last Edit: July 20, 2010, 07:21:10 19:21 by Top » Logged
omni
-Given: 169
-Receive: 176
« Reply #371 on: August 02, 2010, 03:57:14 15:57 »
Hmm,
Are Mac users left out in the cold, I see Windows and Linux but no Mac keygen? Sad
If you require help porting it, I might be able to assist...
Top
-Given: 53
-Receive: 1719
« Reply #372 on: August 21, 2010, 12:24:57 12:24 »
HI-TECH C for the PIC10/12/16 MCU Family v9.80
http://depositfiles.com/files/2qkj1y42p
* New release (19-aug-2010)
« Reply #373 on: August 21, 2010, 01:53:03 13:53 »
Looking at the release notes, thought people who don't read the release note might be interested to know:
Quote from: Release Notes
2.2 Delay Functions
The __delay_ms and __delay_us function descriptions in the manual indicate that a macro _XTAL_FREQ needs to be defined to be the oscillator frequency. This value should be a frequency 4 times the instruction frequency. It may not be the same as the crystal frequency if multipliers are used.
This is it: _XTAL_FREQ = Instruction Working Frequency x 4
For example:
If we have a crystal of 8MHz, then _XTAL_FREQ = 8000000
If we are using 4MHz crystal, and a multiplier makes it 48MHz which becomes the system clock (this is a rough & quick example) then the instruction frequency is 12MHz and _XTAL_FREQ = 48000000, although we are using 4MHz crystal.
Kindly correct me if I am wrong.
HI-TECH C Compiler for PIC10/12/16 MCUs (PRO/Standard/LITE) v9.80 download link
« Last Edit: August 21, 2010, 01:58:13 13:58 by metal » Logged
« Reply #374 on: August 21, 2010, 03:40:24 15:40 »
Metal it's the same in PDS you have to use the pll (40Hz) speed in your code not the xtal freq (10Hz).
as this shows.
Device = 18F2431
Xtal = 40
Config_Start
   OSC = HSPLL ; HS-PLL Enabled   (so physical crystal is actually 10MHz)
