April 26, 2026, 12:22:27 00:22
Author Topic: 89c51 port epansion with 8255 keil c  (Read 8559 times)
Ronydc
« on: January 03, 2008, 10:38:13 10:38 »
 hi friends,
i wanted to increase the port pins with the help of 8255  for 89c51 mcu(atmel)
does any one have the c codes  that can work with keil  uvision (or c51 compiler).
i simply require a sample program with which if i  push a switch on any port pin of 89c51 and i can lit an LED connected on a single 8255 port pin.
your help can make a great fevour for me.
« Last Edit: January 03, 2008, 11:39:40 11:39 by metal » Logged
leptro
-Given: 658
-Receive: 26
« Reply #1 on: January 03, 2008, 03:18:22 15:18 »
hello,
i'am not a keil user nor a 8051 user, here's a link to the 8255 datasheet. http://www.datasheetarchive.com/pdf/496740.pdf
i've read it quickly and seems to be ease to interface.
good luck.
bugmike25
-Given: 15
« Reply #2 on: January 03, 2008, 06:10:32 18:10 »
It is quite simple all u need to do is declare the ports of the 8255:
Usually this is used:
//First 8255 IC
#define porta1 XBYTE [0x8000]
#define portb1 XBYTE [0x8001]
#define portc1 XBYTE [0x8002]
#define cword1 XBYTE [0x8003]
// Second 8255 IC
#define porta2 XBYTE [0x9000]
#define portb2 XBYTE [0x9001]
#define portc2 XBYTE [0x9002]
#define cword2 XBYTE [0x9003]
//Then set the port functions - input, output etc. See datasheet for more info. example:
cword1 = 0x80;
//Add short delay here
porta1 = 0xff;
etc...............
Ronydc
« Reply #3 on: January 03, 2008, 06:36:30 18:36 »
 thanks leptro and bugmike25.
bug, its a nice thing that you have suggested but this do not work with keil. --> xbyte[0x .... ]  // even if we use the absacc.h  header file.
i found out that _at_  key word works well with keil.
like -->  char xdata PA _at_ 0x8000;
            char xdata CR _at_ 0x8003;
and we can take xdata char as-->
            char xdata j;
so that we can put,
void initPPI()
CR = 0x80; /* set all port for output */
main()
while(1)
j = PA; /* read total port A into j*/
now my problem is..  how to read (or write onto) ON A SINGLE PIN of the port..?
can some one try for the code to push a switch on port pin P0.1 and lit an LED on 8255 port pin PA .2  ...?
PLEASE HELP.
THANKS
bugmike25
-Given: 15
« Reply #4 on: January 03, 2008, 06:42:59 18:42 »
It works for sure with Keil. What version are u using? I use uVision3. You must include that header file:
#include <absacc.h>
Ronydc
« Reply #5 on: January 03, 2008, 06:45:51 18:45 »
i am using uvision2... any way. but still my problems stands.
what to do  for the access for a single port pin as i have write in the last paragraph.
bugmike25
-Given: 15
« Reply #6 on: January 03, 2008, 07:02:37 19:02 »
I just found a more recent source code which isnt mine which uses the commands u used.  They only work with the recent versions of Keil (after ARM bought Keil) because i have an older version and that command does not work.
Now if u need to output on port A, pin 2 of the 8255 u must set ur control word to 1000XXXX = 0x80
This means that the 8255 is set to mode 0: basin i/o operation and port A is set as output.
Now when u are dealing with a port is must be treated at a byte.  Therefore if u need to use another pin on Port A for a completely different application you can do this:
Create a variable of unsigned char temp=0,
Then use a variable of type bit to set the state of ur LED; name it LED1,
Then set temp = temp|LED1;
and then shift left using the << command to place the bit in the correct position. This can be done for many different LEDx states.
Then using portA = temp;
However, u cannot just set a single bit on the 8255, you must treat is as a byte.
Ronydc
« Reply #7 on: January 03, 2008, 07:27:38 19:27 »
THX BUG ,
in short i got it, that as you said, the same can be done in following way.
if i want to lit a single led on any port pin.. i have to put there a port value.
like PA = 0X10;  or PA = 20; ( this is ment for some pins on and some off..)
and like tht the port value for the  required port pin.
yes.. this enlitans my mind... dear friend..!!
THANKS.
thanks a lot for your quick helps.
sjn
« Reply #8 on: January 12, 2008, 05:01:26 17:01 »
#define LCD_DATA     XBYTE [0xE000] // Port A
#define KEY_OUT      XBYTE [0xE001] // Port B
#define KEY_IN        XBYTE [0xE002] // Port C
#define CONTROL_PORT     XBYTE [0xE003] // Control Port
#define CONTROL_WORD   0x89  // Port A => O/P , B => O/P , C => I/P
void main(void)
   unsigned char j;
   delay(1000);
   CONTROL_PORT = CONTROL_WORD;
             LCD_DATA  = 0x00;
Ronydc
« Reply #9 on: January 29, 2008, 07:57:22 19:57 »
we had a good discussion abt 8255 ports and pins . thanks friends.
but i have found the shortest way for solving my fundamental problem. and that is--> to use the switches in matrix form. i can use as many switches i like if thay are in matrix.
and the output too i suppose.
thanks any way.
