May 16, 2025, 06:22:26 06:22
Author Topic: MicroBasic strange HEX output  (Read 14575 times)
wh_hsn
« on: February 12, 2006, 07:14:05 07:14 »
Hi all,
I'm trying MicroBasic from the forum & I've tried to compile a code supplied by ME in the 16f877A examples directory:
C:\Program Files\Mikroelektronika\mikroBasic\Examples\P16\P16F877A\Graphic LCD
The output hex looks very strange to me when loaded in OshonSoft!!
Please check the outputs & coment :confused:
thanks
« Last Edit: February 12, 2006, 07:16:08 07:16 by wh_hsn » Logged
wh_hsn
« Reply #1 on: February 14, 2006, 12:13:16 00:13 »
Is it a silly question?!  :confused:
Is the output right or am I missing something?
Thanks for your help.
dobova
« Reply #2 on: February 14, 2006, 08:57:39 08:57 »
Hi wh_hsn
may be you are digging in some not valida code like data declared static, bitmap images or something like that.
Dome
wh_hsn
« Reply #3 on: February 14, 2006, 11:37:51 23:37 »
Hi Dome,
I'm comparing the lst file with the hex file - (adjacent windows in the attached screen shots)
It's within the code not bitmaps nor variables.
If you have MicroBasic would you please try to compile the project:
C:\Program Files\Mikroelektronika\mikroBasic\Examples\P16\P16 F877A\Graphic LCD
& check the output.
thanks,
wh_hsn
« Reply #4 on: February 19, 2006, 03:27:35 03:27 »
Problem solved - thanks Fallout:
http://www.sonsivri.com/forum/showthread.php?p=4408
