May 20, 2025, 01:12:36 01:12
Author Topic: Receiving SMS with the PIC.  (Read 8433 times)
casebsantos
« on: December 22, 2007, 03:29:35 15:29 »
I am testing some commands AT between a PIC and one siemens c65.
How I make for I read the content of a received message? Huh
Since Already, thanks.
bbarney
-Given: 405
-Receive: 545
« Reply #1 on: December 22, 2007, 04:57:43 16:57 »
try searching the forum Shocked Shocked
Rute
-Given: 102
-Receive: 179
« Reply #2 on: December 22, 2007, 05:06:49 17:06 »
Read the SIM (First set the phone  to store sms in sim) If delete 1-st place in sim for SMS after reading,you will find new  sms there.
casebsantos
« Reply #3 on: December 24, 2007, 12:20:26 00:20 »
I need a code sample that will read the received text message.
Somebody can help me? Huh
salej
« Reply #4 on: December 24, 2007, 04:44:04 04:44 »
hello i am new here, you need to use at+cmgread command
Posted on: December 24, 2007, 05:41:40 05:41 - Automerged
you can work with any mobile phone, the at commands are the same with some variations
halil
« Reply #5 on: December 24, 2007, 10:00:21 10:00 »
http://www.riccibitti.com/tinyplanet/tiny_article.htm
Posted on: December 24, 2007, 10:54:27 10:54 - Automerged
Mobile Phone
T68
Developers Guidelines
AT Commands
Online Reference
http://www.anotherurl.com/library/at_test.htm
Posted on: December 24, 2007, 10:59:05 10:59 - Automerged
sorry the links is http://pupius.co.uk/download/misc/t68i-at-commands.pdf
zaliko
« Reply #6 on: January 12, 2008, 03:25:06 15:25 »
hi,
1. ATE0 CR LF - turn off echo from the mobile device
2. AT+CPMS="SM","SM","SM" CR LF - set preffered message storage for mobile device (sim card in our case)
3. AT+CMGF=0 CR LF - trun sms PDU format on
4. AT+CNMI=1,1,0,0,1 CR LF- indicates new incoming sms. when, new sms arrived mobile device generate message like this: +CMTI: <mem>,<index>. where indexis the index of the incoming sms in the sotrage <mem>. in our case mem is SIM card(see command 2). you can catch this this if you enable RX interrupt in MCU.
after you got  +CMTI: <mem>,<index> you can easy read the incoming sms with command:
AT+CMGR=<index>CR LF.
you will got answer:
+CMGR: bla bla CR LF
<pdu>
where <pdu> is the sms text in PDU mode.
decode it and do anything you want.
hope this helps.
p.s. CR = 0x0D LF=0x0A
glenjoy
« Reply #7 on: January 17, 2008, 01:27:09 01:27 »
You need to study the AT commands required for the phone to function properly.
kiashee
-Given: 80
« Reply #8 on: January 23, 2008, 02:48:24 02:48 »
you may also wish to visit www.etsi.org for some GSM standards, like PDU and at-commands.
Kafao
« Reply #9 on: January 25, 2008, 08:50:02 20:50 »
Hello. Anyone has made something for PDU to Normal mode for SMS?
klivi1
« Reply #10 on: January 29, 2008, 09:11:52 09:11 »
you need to connect to mobile phone via RS232. When it works you can send/receive AT commands to phone. A good way to test them using PC and a terminal program. When it works you can implement into MCU.
Concerning PDU I suggest you to use normal SMS mode (if your phone can accept) The PDU is a hard game :-(
strat
-Given: 11
« Reply #11 on: February 26, 2008, 02:25:54 14:25 »
Some important common AT  commands  :
AT+CMGF=1                    -->turn on Text mode
AT+CMGL="REC UNREAD"   --> Read new messages
AT+CMGS=Tel No   +  message --> Send message
AT+CMGD= message text  -->Delete message
After all succeeded commands Pic will wait 'OK' sign.
« Last Edit: February 26, 2008, 02:31:06 14:31 by strat » Logged
free
-Given: 71
« Reply #12 on: February 27, 2008, 10:35:39 22:35 »
If you want to detect every incoming sms, use AT+CNMI command.
You will get the index from +CMTI as respond and write AT+CMGR = <index> to get the all data message.
From the message you can check the sender phone number, message etc.
Hope it helps you
Some dream to escape reality, some to change it forever.
- Soichiro Honda -
sohel
-Given: 169
-Receive: 149
« Reply #13 on: March 10, 2008, 12:29:21 00:29 »
any conveter for pdu to text and show on lcd?
microcom-ecuador
« Reply #14 on: March 22, 2008, 05:59:19 05:59 »
Is most easy work with text mode direct
Ret12_12
-Given: 104
-Receive: 32
« Reply #15 on: March 23, 2008, 12:34:43 00:34 »
If we say CMGF = 1 ( i see above) on the nokia phone then it will accept AT Commands ? instead of the PDU ?
