April 26, 2026, 12:21:09 00:21
Author Topic: AVR Studio SP2 Released  (Read 6458 times)
microkid
-Given: 46
-Receive: 23
« on: December 21, 2007, 12:59:43 00:59 »
AVR Studio SP2 (build571) available for download from atmel website.
winavr AVR gcc has also has a new release 2271221rc1
MicroKid
Never Never Never giveup
nine9
« Reply #1 on: January 21, 2008, 07:04:19 19:04 »
AVR Studio 4.12 is available here without registration:
http://www.atmicroprog.com/download.htm
hate
-Given: 156
-Receive: 355
« Reply #2 on: January 22, 2008, 09:35:02 09:35 »
Direct links from atmel for avr studio and sp2
http://www.atmel.com/dyn/resources/prod_documents/aStudio4b528.exe
http://www.atmel.com/dyn/resources/prod_documents/AVRStudio4.13SP2.exe
Regards...
Regards...
jirawatk
Hello world!!!
« Reply #3 on: January 28, 2008, 10:42:26 10:42 »
If you are using JTAGICE mkI don't forget to download JTAGICE fix to fixes a problem with reading and writing fuses bit.
http://www.atmel.no/beta_ware/as4/413sp2/stk500Dll.zip
demorphica
« Reply #4 on: January 29, 2008, 07:05:19 07:05 »
you will sometimes need to edit your makefiles if you plan to use WinAVR for the compiler in AVRStudio, I have had some problems regarding the .elf compilation. You can try to remove the elf target from the makefile, or use an external makefile, which you will have to generate yourself
