April 07, 2026, 11:05:55 23:05
Author Topic: interrupt 16f877(rb0)  (Read 19808 times)
hamid9543
-Given: 80
« on: January 25, 2006, 11:29:42 23:29 »
hi to all member
this program is very easy !but it not working:confused:
plaese help me
thanks
hardware:pic16f877
pic basic pro
main:
portb=0                           "clear portb"
intcon=%10010000                  "interrupt rb0"
option_reg=%11000000
on interrupt goto int
disable
int:
lcdout $fe,$c0,"yohooo!"
 resume
 enable
 goto main
end
« Reply #1 on: January 26, 2006, 03:04:27 15:04 »
I am glad that you have started writing your own code now, I can say I will help you this time !! As I stated earlier, I will be of great help to members who always try to help their selves first, I can see you passed this stage now Smiley
Compile this code, connect a LED to PORTB.1, use 470 Ohm resistor, when you pull PORTB.0 to low, the LED will flicker for approximatelly 10 seconds. I have already tested this code.
Plz, read the comments carefully so you try to understand why your code didnot work, I see that you haven't setup ADCON1, and started with LCD while haven't posted how you have connected it, review the manual in order to see how its connected.
[SIZE=2][COLOR=Green]@ Device PIC16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF[/COLOR]
[COLOR=Navy]' Tell the compiler that you are using 20MHz crystal[/COLOR]
[B]DEFINE[/B] OSC 20
[B]ON INTERRUPT GOTO[/B] INT
i [B]VAR BYTE[/B] : i = 0
[B]GoSub[/B] InitCPU
MAIN:
[B]WHILE[/B] 1
[B]WEND[/B]
InitCPU:
[COLOR=Navy]' All digital I/O[/COLOR]
ADCON1 = 7
[COLOR=Navy]' PORTB pull-ups are enabled
' Interrupt on falling edge of RB0/INT pin
' TMR0 Internal instruction cycle clock
' Increment on low-to-high transition on RA4/T0CKI pin
' Prescaler is assigned to the Timer0 module
' Prescaler Rate 1:2[/COLOR]
OPTION_REG = %10000000
[COLOR=Navy]' GIE = 1 --> Enables all unmasked interrupts
' INTE = 1 --> Enables the RB0/INT external interrupt
' INTF = 0 --> Clear RB0/INT flag bit to avoive erronous intrrupt[/COLOR]
INTCON = %10010000
[COLOR=Navy]' PORTA all outputs[/COLOR]
TRISA = 0
[COLOR=Navy]' PORTB all outputs except PORTB.0[/COLOR]
TRISB = %00000001
[B]RETURN[/B]
[B]DISABLE[/B]
INT:
[COLOR=Navy]' GIE = 0 --> Disables all unmasked interrupts[/COLOR]
INTCON.7 = 0
[COLOR=Navy]' What you want to do with INT[/COLOR]
[B]FOR[/B]  i = 0 [B]TO[/B] 9
PORTB.1 = 1
[B]PAUSE[/B] 500
PORTB.1 = 0
[B]PAUSE[/B] 500
[B]NEXT[/B]
[COLOR=Navy]' Clear RB0/INT interrupt flag bit[/COLOR]
INTCON.1 = 0
[COLOR=Navy]' GIE = 1 --> Enables all unmasked interrupts[/COLOR]
INTCON.7 = 1
[COLOR=Navy]' Return to main program[/COLOR]
[B]RESUME[/B]
[B]ENABLE[/B]
[B]END[/B][/SIZE]
« Last Edit: January 26, 2006, 04:26:45 16:26 by metal » Logged
hamid9543
-Given: 80
« Reply #2 on: January 26, 2006, 10:18:17 22:18 »
hi metal
thanks for your help and thank for quick replay
i writing code same as you. but it is no working corect:
lcd show:
line1)hamid
line2)(when interrupt) "key= 9........" or "key=3........"
sotware is pbp,proteus 6.7
hardware is pic16f877
code
define osc 20
define lcd_dreg porta
define lcd_dbit 0
define lcd_rsreg porta
define lcd_rsbit 4
define lcd_ereg porte
define lcd_ebit 2
define lcd_bits 4
define lcd_lines 2
lcdout $fe,1,"HAMID"
adcon1=7
option_reg=%10000000
intcon=%10010000
trisb=%00000001
k var byte
for k=0 to 9
disable
int:
lcdout $fe,$c0,"key=",dec k
next k
intcon.1=0
resume
enable
end
harri_el_sucio
« Reply #3 on: January 27, 2006, 05:05:33 17:05 »
Hello METAL:
Thanks Metal for their explanation to are good and to be thankful as it helps to all .
Tt asks:
Enable and Disable you would  to be within routine INT?
Sorry by my bad language
« Reply #4 on: January 27, 2006, 05:40:06 17:40 »
enable & disable are used to diable interrupt check routines that are added by PICBasic pro, the way I plced them is correct.
picstudent
« Reply #5 on: January 29, 2006, 03:04:14 03:04 »
so you are workin on proton+ or ...
... rego ... who are are you really ?
hamid9543
-Given: 80
« Reply #6 on: January 29, 2006, 02:15:12 14:15 »
hi
i write code in pic basic pro
thanks
tasosstr
-Given: 96
-Receive: 14
« Reply #7 on: January 29, 2006, 02:37:19 14:37 »
Hello try this :
define osc 20
define lcd_dbit 0
define lcd_rsbit 4
define lcd_ebit 2
define lcd_bits 4
define lcd_lines 2
adcon1=7
intcon=%10010000
trisb=%00000001
k var byte
for k=0 to 9
    pause 100
next k
disable    'Here start the interrupt modula ...
int:
intcon.1=0
resume
enable
end
Best Regards,
Tasosstr
