sphinx
-Given: 683
-Receive: 389
« on: April 07, 2026, 08:03:41 20:03 » |
this is a portable package for eclipse arm development so it doesnt clutter up os with its stuff first is a text file with files used 1. is a base package only .bat file and examlple projects that starts it all 2. this is the main package ready to to run with example projects 3. files i used to create this when i wanted to make this not much on www for help to create this so use as is or modify or create your own
so one can have multiple confurations without conflicts
one might have to config eclipse but that not any different than using a standard install
have fun
sphinx
-Given: 683
-Receive: 389
« Reply #1 on: April 10, 2026, 12:53:47 00:53 » |
this is project in progress only part thats more or less finalized is the part below the muxer with a lenght matchin of 0.2mil the rest will get some tweaks and maybe some changes kiinda 98% finished schematic wise
have a peek
it is a modified version of gusmans 24bit analyzer with a couple of more bits and using RP2354A
made with ada26
any tips/pointers
« Last Edit: April 10, 2026, 03:39:38 03:39 by sphinx »
sphinx
-Given: 683
-Receive: 389
« Reply #2 on: April 11, 2026, 05:27:18 17:27 » |
this is an updated version of the analyzer with xtal placed
to-do get schematic checked to work since RP2354A is out of my league tune lengths north of muxxers, and tune board overall to get gnd to sneak in a bit more and connect decoupler caps to power considering to change from 4 layer to 6 signals on top/bottom 2 and 5 gnd planes 3 3v3 4 1v1
no traces in middle layers
i got some pwr planes not working correctly so i know of the not appearing as they should vsys and 3v3 and vbus on RT6150B-33GQW
south of muxxers are tuned to 0.2mil diff usb is 0.004 mil diff
tip/mods/changer are very welcome
« Last Edit: April 11, 2026, 06:13:11 18:13 by sphinx »
sphinx
-Given: 683
-Receive: 389
« Reply #3 on: April 12, 2026, 06:22:39 18:22 » |
i forgot to say, check my libs as allways
the schematic was made for a version with big brother chip qfn-80 32bit but got very cramped i made pcb quite a bit bigger, so now this board might work with its big bother
and i will wait at this stage because i want to hear for input on schematics if it works or needs changes to make it work, because some pins might have hidden features, like gpio29, deleting is easy adding to a finished design not so much, thats why it looks this way, this is not final but getting closer
so therefor all inputs are connected, i have found an easy way to fix that
one just connect non used input to gnd and that will make "non-float", then a repour and the traces will be covered by gnd plane to revert shelve plane and connect to net and repour plane and those traces are back with minimal work
« Last Edit: April 12, 2026, 07:30:11 19:30 by sphinx »
sphinx
-Given: 683
-Receive: 389
« Reply #4 on: April 13, 2026, 05:25:09 17:25 » |
since the 24+bit is stopped at the stage of waiting for input on the schematic it self
i thought about to make a project with its bigger brother gpio 0-47 which will be 48bits thats if all pins are usable it is in the beginning stages pic attached
i tried to contact gusman himself and all i got was him insisting that this is an AI creation which it is not
and also complained about some placement of the decoupler capacitors which is an easy to fix if pick-place isnt able to handle placement
also about why i used 1206 well there is more than enough space around the muxxers, also about placement that the decoupler caps was under the chip
and also why everything was connected and not only what was needed, its eaasy to delete but not so easy to add when a board is all routed,
since all that extra didnt create any issues.
that is why i am asking for inout on the schematics, reading close to 1400 pages together plus the errata, where much of it wont make any sense to me i have done some simple things with pics
i have made the portable eclipse for arm and thats what i know about arm and thats not much at all
« Last Edit: April 13, 2026, 06:33:49 18:33 by sphinx »
sphinx
-Given: 683
-Receive: 389
« Reply #5 on: April 15, 2026, 05:22:02 05:22 » |
the big brother changed direction a bit cutting the last 8 bits
added 5v 3v3 2v5 1v8 manually selectable
4 to memory chips
2 for triggers
and 2 spare
and 40 bits analyzed
annotized and ready for placement and a "rough" route
sphinx
-Given: 683
-Receive: 389
« Reply #6 on: April 16, 2026, 10:04:58 22:04 » |
realizing 6 layer boards is a quite a price jump above $180 and 4 layer boards a lot cheaper
so pcb 's are now 4 layer
since tiny holes are expensive to get i will try to get those 0.35mm, fixed holes are 0.35mm and up
3v3 and 1v1 is created by ldo's and same with the vref to be able to use inputs with 5v 3v3 2v5 and 1v8 manually selectable inputs per datasheets are 5 tolerant
1v1 is made adjustable to better support overclocking
extra pins are made test pads
to-do connect mem ic's and their decouple capacitors modify 3v3 and 1v1 pour clear up traces guess other suff not though of right now
pics and proejct files shared
p.s. i hope you like the changes to make it cheaper to make
sphinx
-Given: 683
-Receive: 389
« Reply #7 on: Today at 04:28:17 AM » |
project finished no document nor gerbers created
please check schematics and schematic components as well as footprints for any mishaps/errore
everything connected 4 layer board with 0.35 minimum holes 40 pin analyzing 2 trigger inputs 3v3 1v1 where 1v1 is adjutable for overclocking selectable voltage input 5v 3v3 2v5 1v8, 5v tolerant 4 x 64mbit memory chips tune it to your preferences
sphinx
-Given: 683
-Receive: 389
« Reply #8 on: Today at 09:35:25 AM » |
according to jlcpcb 0.3mm with 0.45mm pad is no extra cost
and via with 0.2mm hole 0.45mm pad no extra cost either
