April 02, 2026, 08:20:07 20:20
Author Topic: M5stack voltmeter  (Read 5823 times)
-Given: 582
« on: April 27, 2024, 08:41:16 08:41 »
Just a quick question it says that the m5stack voltmeter can measure up to +/-36v
I was just wondering would it be possible to modify it so that it can measure +/-99v absolute voltage ?
Here is the unit I’m talking about
https://thepihut.com/products/voltmeter-unit-ads1115?variant=40639062212803&currency=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjwxLKxBhA7EiwAXO0R0AMRAb8CxLa1cHosetK2a7DsY-WmK3wBwx6ZPV-xsVZqoaTx7aTAXhoC0uYQAvD_BwE
sphinx
Online Online
-Given: 682
-Receive: 377
« Reply #1 on: April 27, 2024, 09:32:46 09:32 »
if you dont have the schematics it might get trickier to find the the voltage divider where youu could change the range of the input voltage but i would think it is possible to modify,
unless its potted with some gunk inside or components are wiped of identification numbers
if it is high impedance input you could allwayes make an external voltage divider
-Given: 582
« Reply #2 on: April 27, 2024, 10:07:47 10:07 »
This is the schematic  for it.
If I'm correct and if I do the calculations with the 11k and 680k resistor values on the input I would get +/- 573Mv  so for 99V then the 680K would need to be 2M ?
sphinx
Online Online
-Given: 682
-Receive: 377
« Reply #3 on: April 27, 2024, 10:25:50 10:25 »
using a voltage calculator i get 1889.524kohms
Posted on: 2024-04-27, 10:40:59 - Automerged
you can allways lower the 11kohms to get some othe value depending on the values one can get
and how exact you want it to be
the more bits you use the more noice you will have as well 2^16 will give you 1.5mV resolution and that can get noisy this needs to be calculated for as well
« Last Edit: April 27, 2024, 10:40:06 10:40 by sphinx » Logged
