May 25, 2025, 12:24:11 12:24
Author Topic: ICSP with MP monitoring  (Read 4612 times)
« on: January 28, 2021, 02:31:28 14:31 »
I m unsure if this will work OK for PICs, what do guys think?
Old_but_Alive
-Given: 771
-Receive: 122
« Reply #1 on: January 28, 2021, 02:49:11 14:49 »
depends on whats connected to mclr, PGC, PGD.
I would connect a 10K between the pins and the rest of the cicruit unless they are outputs.
-Receive: 992
« Reply #2 on: January 28, 2021, 04:10:46 16:10 »
This is what you can do if you want to more safe than sorry
« Reply #3 on: January 29, 2021, 05:07:42 17:07 »
Nothing is connected to these pins other than the one I have shown in the 1st post.
dennis78
-Given: 276
-Receive: 155
« Reply #4 on: January 29, 2021, 10:41:44 22:41 »
I don't work with PICs (and not plan forever Smiley ), but If I remember PICs use about 13V on MCLR pin to enter(or all time during programming) in programming mode.
In this case:
1. reset circuit possible can limit this voltage to Vcc+Vd(due to protection diode or because it exceed absolute maximum voltage ratings conditions if protection diodes not exist)
2.R2 also can limit voltage programming -> you can expect problems during ICSP.
In this situation I will add resistor between \RESET output and MCLR pin on mcu (possible>=10k it depend what is PIC programmer current capability on output for MCLR, maybe 1k is enough?). Maybe this will not work for >10k values in normal reset situation if PIC have internal pull up for MCLR pin, but you must read docs and chose good value.
« Last Edit: January 29, 2021, 10:59:26 22:59 by dennis78 » Logged
h0nk
-Given: 250
-Receive: 234
« Reply #5 on: January 29, 2021, 11:13:08 23:13 »
Hello,
it seens that the APX8035 has an O.C.-Output.
I would assume that this will work.
But You should check the maximum ratiings of this output.
Best Regards
dennis78
-Given: 276
-Receive: 155
« Reply #6 on: January 29, 2021, 11:39:59 23:39 »
O.C. output isn't guarantee that protection diodes don't exist.
Absoulte max ratings for reset output = 6V=Vcc -> possible that circuit have protection diodes is very high Smiley
Datasheet isn't precise and full informative
« Last Edit: January 30, 2021, 10:56:02 10:56 by dennis78 » Logged
motox
-Given: 260
-Receive: 331
« Reply #7 on: January 30, 2021, 05:51:34 17:51 »
Don't put more than 5.5V on the APX output pin without a limiting/protection circuit.
I recommend reading the following application notes when using supervisors with PICs:
 - AN820A System Supervisors in ICSP Architectures
 - TB087 Using Voltage Supervisors with PIC Microcontroller Systems which Implement In-Circuit Serial Programming
I usually put two 10kΩ pull-down resistors on the PGD and PGC lines. Don't use pull-ups here, because most ICD programmers have internal 4.7kΩ pull-down resistors.
h0nk
-Given: 250
-Receive: 234
« Reply #8 on: January 30, 2021, 10:04:12 22:04 »
Its not O.C., its O.D.: Open Drain.
A true O.C. would have no problems with the programming voltage.
Use a either a supervisor without clamping or an active high output
together with a npn-bjt.
I had no problems with the usual recommended MCLR-connection.
http://www.sonsivri.to/forum/index.php?action=dlattach;topic=69036.0;attach=32197
Best Regards
« Reply #9 on: January 31, 2021, 12:11:36 00:11 »
I see, thank you all, circuit is busted, I presume.
