April 29, 2026, 08:20:57 08:20
Author Topic: PIC-PC Serial Communication  (Read 6005 times)
picstart
« on: January 10, 2006, 03:31:34 15:31 »
I want to interface my motor speed controller circuit using pic to a PC so that I can input desired rpm using PC and view the current motor rpm as well.
Can anyone give me more ideas and links ?
Thank you!
jeanninemtv
-Given: 57
-Receive: 25
« Reply #1 on: January 10, 2006, 04:19:06 16:19 »
i think you can check www.rentron.com  for VB6.0 samples of serial comm.
The pic part ...  i think you-re more experienced PIC user ..
Lumos
-Given: 74
« Reply #2 on: January 14, 2006, 04:54:08 04:54 »
hi picstart
this works with TMS Async32 for Delphi wonderfully.
I also use.
« Last Edit: January 16, 2006, 06:47:59 06:47 by Lumos » Logged
pl4tonas
-Given: 330
-Receive: 196
« Reply #3 on: January 18, 2006, 05:34:03 17:34 »
Also have in mind that a MAX232 serial level converter IC is needed. (sugested for more reliable operation)
Lumos
-Given: 74
« Reply #4 on: January 18, 2006, 06:48:04 18:48 »
excuse my bug.
Max 232 and 233 is right as hardware and tms as software
was too recessed in the RS232 programming.
shailesh5
Translator
-Given: 56
« Reply #5 on: February 01, 2007, 09:10:58 09:10 »
you can use labview to develop a user interface on pc as ther are many examples , e.g  bluetooth ,ethernet coms and so on or you can use visaul basic also but its demands a bit of coding i see that labview is easier u just drag and configure
shailesh
martinisonline
-Receive: 19
« Reply #6 on: January 28, 2008, 02:55:49 02:55 »
shailesh
I will take this topic to ask a similar question!
I did some little projects using pics, but now i wanna make a project and i wanna take some control via PC on the pic!
I did a search last couple of days try to find the best way (easy? Wink) to do it!
I aready used UART to comunicate but using just Hyperterminal, and now i would like to create some interface on PC side!
What kind of software you recomend to program a simple interface?
You talked about Labview!, is it possible with this software comunicate via hardware COM port to PIC? and with a virtual COM port (emuladed via USB)? Is it possible using direct USB port as HID or CDC?
Thanks in advance!
bliviudaniel
« Reply #7 on: January 28, 2008, 09:16:31 09:16 »
I used Visual C++.
You may found on internet some classes for serial communication in C++.
BLD
o_cientista
« Reply #8 on: February 07, 2008, 03:23:32 15:23 »
Good morning, friend!
      Here's an example that I am sending you
      http://rapidshare.com/files/63303746/Comunica__o_RS232.rar
