April 11, 2026, 07:37:40 19:37
Author Topic: PHPMaker v5.0.1.6  (Read 4578 times)
o2
-Given: 41
-Receive: 405
« on: November 22, 2007, 05:51:10 05:51 »
PHPMaker is a powerful automation tool that can generate a full set of PHP quickly from MySQL database. Using PHPMaker, you can instantly create Web sites that allow users to view, edit, search, add and delete records on the Web. PHPMaker is designed for high flexibility, numerous options enable you to generate PHP applications that best suits your needs. The generated codes are clean, straightforward and easy-to-customize. The PHP scripts can be run on both Windows or Linux/Unix servers. PHPMaker can save you tons of time and is suitable for both beginners and experienced develpers alike.
Prog:
http://www.ware8.com/download.asp?id=160&gdcnc-downs2=6afe70df47b37433
Keygen:
http://www.enfull.com/download.asp?newid={60A8520A-5D70-409D-9F47-5791BED9E431}&down=teldown1
