May 20, 2025, 12:20:54 00:20
Author Topic: Multi VGA over LAN  (Read 4200 times)
Silent_Thunder
-Given: 56
-Receive: 20
« on: December 24, 2019, 01:34:39 13:34 »
Hi everybody;
I have a project that needs to display data on multi VGA monitors through the LAN
that data will be some sort of a web page, but the data that will be displayed is different for each monitor.
any idea of a device that convert data from the LAN to drive VGA monitor, and have to have a unique IP over the network, and can read a web page from a server.
I've searched the web for such a solution but came up empty handed .  Sad
Thank you in advance for your help.
BharatSujanani
-Given: 32
-Receive: 24
All is Well
« Reply #1 on: December 25, 2019, 06:14:23 06:14 »
You should try smart tv instead of VGA monitor. In smart tv you can browse different page for different tv and connect all tvs to one wifi router.
Bharat Sujanani
sadman
-Given: 1898
-Receive: 3006
Sow The Seeds of Love
« Reply #2 on: December 25, 2019, 07:11:55 07:11 »
Hi everybody;
hi
you can used LAN to VGA adapter and connect them all trough Ethernet you can find VGA adapter from amazon or alibaba
https://www.amazon.com/Converter-MACTIS-Ethernet-Adapter-Female/dp/B074P2SSLX
https://www.alibaba.com/product-detail/high-quality-VGA-TO-RJ45-CAT5_60241798897.html?spm=a2700.7724857.normalList.152.57844b55DftSb0
sadman
Silent_Thunder
-Given: 56
-Receive: 20
« Reply #3 on: December 25, 2019, 07:38:33 07:38 »
hi,
Thank you for your support.
The point is I can't use smart TV, cuz of the size, I want to use 17" or max 19" monitor
and for the RJ45 to VGA adapter, that is useful as extender in this case all monitors will display same data.
I need a solution that have a dedicated IP or it is smart to access data from a server.
sadman
-Given: 1898
-Receive: 3006
« Reply #4 on: December 25, 2019, 10:57:53 10:57 »
hi,
There are Ethernet modules that can control different ips here is some guidance from national instrument and google is our best friend
may this help you.
http://www.ni.com/product-documentation/12558/en/
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9ULSA0
https://superuser.com/questions/1318091/multiple-nic-routing-across-different-subnets
https://community.spiceworks.com/topic/2145428-multiple-nics-different-subnets-win10-config-question
https://social.technet.microsoft.com/Forums/ie/en-US/9c8502cb-ca52-4b07-b9b7-17514d262eec/using-dual-nics-for-different-lans?forum=winserverNIS
sadman
Posted on: December 25, 2019, 04:38:18 04:38 - Automerged
i think i found what you want to do
https://www.blackbox.co.uk/gb-gb/page/44064/Resources/Technical-Resources/Black-Box-Explains/Multimedia/What-Is-HDMI-over-Ethernet-and-How-Does-it-Work
https://spacedesk.net/multi-monitor-app-virtual-display-screen-software-video-wall
https://monitorsanywhere.com/
https://monitorsanywhere.com/hdmi-over-lan-explained/
« Last Edit: December 26, 2019, 04:22:14 04:22 by sadman » Logged
