April 10, 2026, 10:15:01 10:15
Author Topic: MikroBasic 2.2 which is the good crack  (Read 18600 times)
manny
-Given: 21
« on: January 07, 2006, 01:00:47 01:00 »
Hi which  is the correct crack to use to make Mikrobasic 2.2 work so it compiles code MOR THAN 2k.
who has the right crack...  And where can i/we get it from...
Manny
olotill
« Reply #1 on: January 07, 2006, 03:19:44 03:19 »
Hello...
The best  was done by POSEK GROUP, you have to look for it in the other post.... It works 100%...
Best Regards
manny
-Given: 21
« Reply #2 on: January 09, 2006, 08:07:08 08:07 »
Thanks olotill
Manny
« Reply #3 on: January 09, 2006, 03:43:08 15:43 »
I made this patch today, use the accompanying license in order for the patched exe to work.
MetaL
tasosstr
-Given: 96
-Receive: 14
« Reply #4 on: January 09, 2006, 07:33:49 19:33 »
Hello Metal,
You Are A REALY C * R * A * C * K * E * R  ! ! !
VERY NICE ! ! !
When you have time can you do the same on mikrobasic for Avr ?
Thank you very much  ! ! !
Best Regards,
Tasosstr
Bacra2k
-Given: 11
-Receive: 22
« Reply #5 on: January 10, 2006, 07:08:43 07:08 »
Good work Metal
now this fix really works
Thx for sharing
Salu2
bajrang
-Given: 245
-Receive: 79
« Reply #6 on: January 10, 2006, 09:04:08 09:04 »
Dear Metal,
Finally you did it! Many thanks to you and your sincere efforts!
The crack works a 100%. I have even tested on the hardware.
keep up the good work
warm regards,
bajrang
LONG-LIVE SONSIVRI FORUM
manny
-Given: 21
« Reply #7 on: January 10, 2006, 09:28:07 09:28 »
Thnaks Metal for all your help....
all the best to you...
Manny
freddyg
« Reply #8 on: January 10, 2006, 06:35:39 18:35 »
Hi Metal.
Where do I put the license file?
I'm not sure what you mean when you say "use the accompanying license".
Thanks.
Freddy
« Reply #9 on: January 10, 2006, 07:09:00 19:09 »
Put it in mikrobasic folder.
freddyg
« Reply #10 on: January 10, 2006, 07:12:31 19:12 »
Thanks Metal.
Sorry if it seemed a silly question.
Freddy
freddyg
« Reply #11 on: January 10, 2006, 07:32:23 19:32 »
Is it just me, or is the GUI rather buggy...
Open two projects eg. Led_blinking.pbas and GlcdTest.pbas so there are two project tabs open. Build the first, build the second, then try building both again. It keeps on compiling the same project even if the other one is active. Also, if I close Led_blinking.pbas then build GlcdTest.pbas, it will still compile Led_blinking.pbas ie. the first one I opened. The only way I can then compile the second one again is if I close the program down and start it up again .
(using these two projects as examples makes it easy to see which is being built because of the difference in sizes).
It's a shame because it seems a very good program otherwise.
Freddy
tasosstr
-Given: 96
-Receive: 14
« Reply #12 on: January 10, 2006, 08:18:27 20:18 »
Hi freddyg,
The way that compiler works is:
Close all you're project and after create new file and compile or open an existing and  after compile.
Best Regards,
TasosStr
picstart
« Reply #13 on: January 17, 2006, 03:52:54 15:52 »
Quote from: iceman_top2000
Hi ALL
I am trying to download the patch file, but nothing happed when I click the link above, It does not start downloading
Can anybody help me please
How I can download the patch?
Instead of clicking try choosing save link as... from the right-click menu.
hth
« Reply #14 on: January 17, 2006, 06:38:12 18:38 »
Don't worry, I will upload to rapidshare tomorrow.
-Receive: 14
« Reply #15 on: January 18, 2006, 03:18:31 03:18 »
Thnaks Metal for GREAT work.Smiley
« Reply #16 on: January 18, 2006, 08:58:43 20:58 »
It seems there is a problem on the forum, I can't download any attachment. Suggest another site into which I can upload mikrobasic patch, I can't upload to rapidshare, neither megaupload.
« Reply #17 on: January 19, 2006, 04:29:31 04:29 »
You can download it from here.
leppod<-
« Reply #18 on: January 20, 2006, 02:18:02 02:18 »
Thanks MeTaL!
xDigimonx
« Reply #19 on: January 20, 2006, 03:55:30 03:55 »
Thanks MeTaL
