abbas1707
-Given: 15
-Receive: 25
« on: November 16, 2007, 01:56:17 13:56 » |
Hi All My Friends  if i can collect some data by microcontroller AT89c51 and i can send it by RS232 to a PC how can i monitor this data from another location through the internet can one help
A Thousand Miles Journey Starts With a Single Step
SONSiVRi
Administrator
-Given: 75
-Receive: 405
« Reply #1 on: November 16, 2007, 02:31:15 14:31 » |
Hi All My Friends  if i can collect some data by microcontroller AT89c51 and i can send it by RS232 to a PC how can i monitor this data from another location through the internet can one help you can create application that uses server component (indy for delphi). assign non-using port to that component, then you can point your PC by IP:port notation. you will able to control your atmel directly over serial port
- Houston, we have a problem.
digitalmg
-Given: 145
-Receive: 113
« Reply #2 on: November 16, 2007, 04:44:08 16:44 » |
gosu
« Reply #4 on: November 21, 2007, 01:39:50 01:39 » |
ft232
mick
-Given: 2239
-Receive: 138
« Reply #5 on: November 30, 2007, 09:34:43 21:34 » |
Elektor dec 2007
tae
« Reply #6 on: December 01, 2007, 12:47:14 00:47 » |
you have to connect your micro to internet directly or through pc. If latter is not the case - implement ppp and connect your micro to modem with dialup to isp . then . As as usual ip does change with every logon if your contract with isp does not include static ip arrangement . If latter - you are in business . If not you have to somehow implement dynamic dns support in your micro or in remote pc connected to internet . Connection peers must know their addresses . At least one have to be known .
Yet also it can be possible to adsl router with ethernet - ethernet connectivity in mcu must be done .
For ppp there is a book tcp ip lean for pic controllers . Also some free stacks should be in internet supporting .
Other way? Connection through mobile . Or direct dial up from micro to remote pc .
khan_yousaf
-Given: 33
-Receive: 89
« Reply #7 on: May 14, 2008, 07:45:03 19:45 » |
vinculum ics from ftdi......very easy and handy
afreakmachine
« Reply #8 on: May 18, 2008, 05:38:38 05:38 » |
u would need ethernet modude with tcp/ip stack code, try search on google for dev board "mcs-51 ethernet"
LabBoy
« Reply #9 on: May 23, 2008, 11:47:18 11:47 » |
Hi, If you can transfer data between MCU and computer. Next, you should try to develope a software on computer whit C++ Builder, VisualC++ Delphie or HTML...
anatom
« Reply #10 on: July 29, 2008, 08:20:02 08:20 » |
Anyone has used SNMP protocol?
Joe_jj
« Reply #11 on: July 29, 2008, 03:15:54 15:15 » |
Monitor for? if just for see the data.U can use the serial port monitor tools and the remote PC program(like logmein or teamviewer) to control and monitor ur data.
medik
-Given: 76
« Reply #12 on: September 11, 2009, 10:39:58 22:39 » |
The new PIC18F97J60 is an all-in-one solution as it has 128kb of flash, about 4k of Ram with inbuilt ethernet facility so no need for Enc28J60 except you don't program PIC at all.
Mega32
-Given: 273
-Receive: 37
« Reply #13 on: September 11, 2009, 10:55:37 22:55 » |
@medik Did you really "waste" your first post here in reviving a "More than One year old thread" ? I do hope the OP have found his solution by now ....
Mega32
