Tien Nguyen
« on: November 04, 2017, 03:32:34 15:32 » |
Hi everyone, I completed Digital IC Tester project so I would like to share to you. See code and schematic as attached file.  If you have any question for this project, you can send email to me. Email: nguyenhuutien.dap@gmail.com
piccolo
-Given: 867
-Receive: 996
« Reply #1 on: November 04, 2017, 08:42:40 20:42 » |
Hi, Can you provide more information?
« Reply #2 on: November 05, 2017, 06:56:25 06:56 » |
the comments in the code are n Vietnamese.
Tien Nguyen
« Reply #3 on: November 05, 2017, 04:01:27 16:01 » |
Hi piccolo
What information do you need?
Posted on: November 05, 2017, 04:58:00 16:58 - Automerged
Hi metal,
Yes. If you like this project, I will translate to English for you.
piccolo
-Given: 867
-Receive: 996
« Reply #4 on: November 05, 2017, 08:38:09 20:38 » |
Hi Tien Nguyen, Kindly, a brief description of the circuit, what is it useful and, if possible, have the translation of the comments in the code, to English.
M@X77
-Given: 46
« Reply #5 on: November 10, 2017, 10:17:49 22:17 » |
Hi Tien, is interesting, do you used two mcu because not have a lot of pins? Did you think to use port A and E to drive LCD or to use a pcf8574p to drive LCD serially with i2c?
fpgaguy
-Receive: 166
« Reply #6 on: November 10, 2017, 11:01:45 23:01 » |
I'm pretty sure the second micro is to control the display only - although it's meant to check only certain chips (your typical TTL 74xxx) - IE check the code out a bit
sadman
Online
-Given: 1899
-Receive: 3006
Sow The Seeds of Love
« Reply #7 on: November 11, 2017, 08:29:17 08:29 » |
a tester for digital I.C for complete range is publish early 90's in elektor based on 8051 series of processor i will search it in my backup and share it here
sadman
Online
-Given: 1899
-Receive: 3006
« Reply #8 on: November 12, 2017, 12:56:15 12:56 » |
so finally found it
Tien Nguyen
« Reply #9 on: March 03, 2018, 10:04:43 10:04 » |
Hi all, If I have enough time, I will translate the comments in my project to upload for you. Hope someone develops it.
« Reply #10 on: March 03, 2018, 11:08:44 11:08 » |
Without an A/D and D/A on each pin, this is pretty useless for anything but a cursory screen for DOA parts.
You could have gotten half of that test functionality by remapping the pins to the analog pin ports...
