April 08, 2026, 06:13:52 18:13
Author Topic: Help for lcd code for PICBASIC PRO  (Read 20255 times)
8051
-Receive: 14
« on: January 04, 2006, 03:18:41 15:18 »
I try to show Ascii data on lcd from rs232 9600 baudrae 8 byte data length
but lcd only show  " Value"
Xtal 4 mhz
chip 16f84
Please help me
INCLUDE "MODEDEFS.BAS"
DEFINE LCD_DREG PORTB
DEFINE LCD_BIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 5
DEFINE LCD_BITS 4
       DEFINE LCD_LINE 2
    SI      con     9
    B0      var     BYTE
loop:
      SERIN SI,N9600,B0
      PAUSE 10
      LCDOUT $FE,1
LCDOUT "Value ",B0
      GOTO LOOP
END
« Last Edit: January 05, 2006, 03:16:24 03:16 by 8051 » Logged
joker12
-Receive: 80
« Reply #1 on: January 04, 2006, 03:58:39 15:58 »
One thing I noticed is you are using a 4 bit bus, correct?
Your define LCD_BIT 0 should be LCD_DBIT 4 according to the manual page 92
Depends on how you wired it up. I assume you have the upper 4 bits of the display connected
Joker12
« Last Edit: January 04, 2006, 04:10:49 16:10 by joker12 » Logged
8051
-Receive: 14
« Reply #2 on: January 05, 2006, 03:03:20 03:03 »
I use as
PORTB.0 --- D4
PORTB.1 --- D5
PORTB.2 --- D6
PORTB.3 --- D7
PORTB.4 --- RS
PORTB.5 --- E
PORTA.1 --- SERIN
dezso
-Given: 34
-Receive: 137
« Reply #3 on: January 05, 2006, 06:53:37 06:53 »
Try :  "LCDOUT "Value: ", Dec B0"
dezso:
-Receive: 14
« Reply #4 on: January 05, 2006, 11:52:46 11:52 »
After Try this :  "LCDOUT "Value: ", Dec B0"
when no signal
LCD show   ---   Value : 0
after eny  signal ---  Value : 255
i also tryied     B0  VAR  BYTE   and    B0  VAR  WORD
tasosstr
-Given: 96
-Receive: 14
« Reply #5 on: January 05, 2006, 04:05:49 16:05 »
You're code say:
loop:
      SERIN SI,N9600,B0
      PAUSE 10
      LCDOUT $FE,1
LCDOUT "Value ",B0
      GOTO LOOP
Try that:
loop:
       SERIN SI,N9600,B0
LCDOUT $FE,1 'Here you clear the lcd
 LCDOUT "Value ",dec B0   'Here print into lcd
       pause 400         'wait 0.4 Second (If you decrease the time then you can not see the data but only show the "value" to blinking fast.)
       GOTO LOOP       'Then receive again the next ....
Best Regards,
TasosStr
-Given: 405
-Receive: 545
« Reply #6 on: January 05, 2006, 10:34:48 22:34 »
go here you will find a lot of good info
http://www.picbasic.co.uk/forum/
dezso
-Given: 34
-Receive: 137
« Reply #7 on: January 06, 2006, 12:16:06 00:16 »
oK
This one is working.
dezso:
' Define LCD registers and bits
Define  LCD_DREG        PORTB
Define  LCD_DBIT        4
Define  LCD_RSREG       PORTB
Define  LCD_RSBIT       4
Define  LCD_EREG        PORTB
Define  LCD_EBIT        5
        Pause 100       ' Wait for LCD to start up
Wars:   Tx  var     PORTC.6
        Rx  Var     PORTC.7
        rec var     byte[1]
loop:   serin2 rx, 84, [STR rec\1]
outlcd: lcdout $fe, 1, "RECEIVE = ", STR rec\1
        goto    loop
