March 13, 2026, 03:45:08 15:45
Author Topic: [Req] Invite Norbert  (Read 3902 times)
Norbert
« on: July 24, 2017, 01:34:59 13:34 »
CountryFrance
NoteHello,
 I'm engineer in electronics, member of honeywell.com. Electronic is my profession and hobby to.
25 years power electronics design analog and digital power conversion including variable speed drives, control and measuremet, switching power supplies. Hopefully I can add something to the discussions and also learn from others.
If you don't have rights to invite me, can you add post to:
http://www.sonsivri.to/forum/index.php?topic=58473.0
1) Can you check pickit2 USB connection. Click the Start  button, and then, on the Start menu, click Devices and Printers.
2) windows demonstrate "Pickit2", if not, then reinstale driver (from Microchip package, no from Microsoft)
3) Can you give us more details about the problem. 32 bit application  works on Windows 64 bit usually well. Some times you need to set compatible mod, some times you start application as administrator, some times you need changes on registers (use regedit)  ...
Thank you
Norbert
Invitation System
Invitation status : Person is registered and he/she is member now.
Permission : You cannot invite. Because you are guest.
Your credits : You have no invitation credits.
-Receive: 4452
« Reply #1 on: July 28, 2017, 07:16:32 19:16 »
This member is invited by me. Registration isn't completed yet.
Note: This message sent by the system behalf of pickit2.
Norbert
-Given: 8
« Reply #2 on: July 28, 2017, 08:42:15 20:42 »
Thank you for invitation. Registration is done.
Note: This message sent by the system behalf of Norbert.
