March 03, 2026, 04:28:39 16:28
Author Topic: PIC Programmer  (Read 9655 times)
embromation
-Given: 50
-Receive: 478
« on: November 13, 2007, 01:38:21 01:38 »
Go to:
http://www.sonsivri.com/forum/index.php?topic=8051.0
« Last Edit: July 24, 2008, 03:05:10 03:05 by embromation » Logged
Share your knowledge!
iphone
-Given: 115
« Reply #1 on: November 13, 2007, 03:04:33 03:04 »
Do you build it ?
What's the extra feature compare to old JDM programmer ?
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #2 on: November 13, 2007, 05:39:27 05:39 »
This is the MultiPic Prog 5v2, but in the original model there is a lot of error in the zif socket configuration, but in this circuit you have eliminate these errors and now it can support the I2c eeprom. Nice PCB work embromation. I have made it from 3 month ago and it is worked perfectly with the GTP USB zif configuration. I use it with WINPIC800 v3.55  Grin Grin
This is a 3D picture of embromation board
                V
« Last Edit: November 13, 2007, 06:03:25 06:03 by Ahmad_k » Logged
mizk_electro
« Reply #3 on: November 15, 2007, 04:43:24 04:43 »
What the diffrent ? ... extra features ? ... Huh
hodahel
-Given: 189
Catch me...
« Reply #4 on: November 15, 2007, 06:36:53 06:36 »
Yes..please tell us what are the advantage over the old hardware?
sohel
-Given: 169
-Receive: 149
« Reply #5 on: November 19, 2007, 05:26:12 17:26 »
any universal design for icd2 icsp? 40pin zip socet.
« Last Edit: November 19, 2007, 06:23:41 18:23 by sohel » Logged
sohel
-Given: 169
-Receive: 149
« Reply #6 on: November 19, 2007, 07:36:13 19:36 »
I am talking about 40 pin zip socet, any design universal for 8 pin to 40 pin? i want to use it for ICD2. Huh by the way u use ic base for insert. Huh
-Given: 499
« Reply #7 on: November 19, 2007, 10:16:43 22:16 »
Wonder if this one could program 12F675 properly.. Jdm cannot but Fang's RCD can.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #8 on: November 20, 2007, 05:34:42 05:34 »
Yes it can Cheesy i have tested this programer with almost all PIC series and it works great. I have used WINPIC800 3.55g
slapdash41
-Given: 17
« Reply #9 on: November 21, 2007, 01:48:04 01:48 »
can someone convert to other format such as pdf/doc...ready to print format ..thanks again...
jeanninemtv
-Given: 57
-Receive: 25
« Reply #10 on: November 22, 2007, 05:55:08 17:55 »
I cant setup this P2GC olimex clone with winpic8000
any help?
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #11 on: November 22, 2007, 07:59:12 19:59 »
any help?
what is this word Huh  P2GC ?
jeanninemtv
-Given: 57
-Receive: 25
« Reply #12 on: November 28, 2007, 04:20:19 16:20 »
check olimex homepage...
the circuit that our friend did is not feng prog but the olimex serial port programmer....
sheriefaly
« Reply #13 on: January 28, 2008, 08:29:05 08:29 »
have any 1 the sheet of this serial prog. thanks in advance
bk3e
« Reply #14 on: January 29, 2008, 02:28:03 02:28 »
I can't see your schematic of your programmer. Pls give me link?
sheriefaly
« Reply #15 on: January 29, 2008, 09:28:13 09:28 »
missed schematic of your programmer pls re upload
DINESHjp
« Reply #16 on: September 12, 2008, 02:06:20 02:06 »
i have found this modified jdm programmer on the net i have tesetd it and it work fine
i have uploaded all the file including pcb layout
http://www.4shared.com/file/62666549/67036cf1/jdm_mod.html
