May 22, 2025, 07:11:08 07:11
Author Topic: Programing Cortex A series  (Read 6006 times)
alberto110
-Given: 50
« on: April 29, 2017, 11:24:53 11:24 »
hi  ,
for a project i need a high speed MCU or MPU ( >400MHZ) but M3 or M4 max frq is less than 250 mhz . so is that possible using Cortex A series , for example AtsamA5
directly without OS and reach 500 Mhz clock , with or without cpu cache ,  and using connected external dram and other prepherals .
i mean , can i scan gpio at 500 mhz   ?
digitalmg
-Given: 140
-Receive: 113
« Reply #1 on: April 29, 2017, 01:08:33 13:08 »
I used stm32407 (FSMC ,Flexible Static Memory Controller ) connected in parallel with a fpga to read the input at high speed.
alberto110
-Given: 50
« Reply #2 on: April 29, 2017, 01:37:56 13:37 »
Good , but for large amount of code to be executed an MPU is needed . FPGA cost very high comparing with MPU .
bobcat1
-Given: 4405
-Receive: 96
« Reply #3 on: April 30, 2017, 08:10:24 08:10 »
HI Try
STM32H7xxx microcontroller working at 400mhz
All the best
Bobi
alberto110
-Given: 50
« Reply #4 on: May 12, 2017, 06:03:18 18:03 »
thanks a lot . STM32H7xxx is under development . most of them !.
 also , for using the cash in samad21 ,is that necessary to use an operating system ?
exactly i want to know , for use the cache , we should set up it and it continue to work itself , or a dynamic managing program should run beside other application programs ?
bigtoy
-Given: 348
-Receive: 297
« Reply #5 on: May 18, 2017, 05:17:33 05:17 »
If you're talking about instruction & data cache, then it's just a matter of setting it up, and after that it'll run by itself.
