March 11, 2026, 02:17:44 02:17
Author Topic: USB flash drive case repair - heat shrinking tube and spring  (Read 5879 times)
Signal
-Given: 113
-Receive: 81
« on: January 23, 2017, 09:53:56 21:53 »
Accidentially an usb plug detached from plastic cover at last attempt to pull it from PC. Fortunately the remaining case is easily solderable.
1 mm copper wire became an interface between spring and case. An option to drill little holes to attach spring directly lost its chance to be implemented.
Heat shinking tube was the only candidate for cover.
Resulting construction looks naturally on key ring
A spring works as a buffer ...
... reducing mechanical stress
bigtoy
-Given: 365
-Receive: 297
« Reply #1 on: January 24, 2017, 04:59:54 04:59 »
Nice recovery.  I hope the spring holds up to wear & tear.
zac
-Given: 82
-Receive: 57
« Reply #2 on: January 24, 2017, 09:53:01 21:53 »
Adhesive lined heatshrink tubing might be more durable:
https://www.amazon.com/URBEST-117Pcs-Dual-Adhesive-Lined-Shrink/dp/B01A6U6PAM
Another possibility is to glue the original enclosure.  Silicone or polyurethane sealant/adhesive might work.  If the enclosure is silicone, few adhesives will stick.
