April 26, 2026, 02:23:27 02:23
Author Topic: ICCV7 Pro Loader Patch V1.0.1.0 for ICCV7 C Compiler Serial  (Read 8284 times)
dcg10m
« on: November 08, 2007, 04:21:28 04:21 »
Patch iccV7avr V7.16 OK!
ICCV7ProLoader Revision History
V1.0.1.0 Release - November 8th, 2007
   - update from V1.0.0.0
   - patch 4 minutes limit in ICCV7
   - support for iccv7avr(AVR) v7.01 to v7.14C or later
   - support for iccv7arm(ARM) v7.00 to v7.08 or later
   - support for iccv7430(MSP430) v7.00 to v7.06A or later
   - support for iccv712(CPU12) v7.00 to v7.03A or later
V1.0.0.3 Release - September 28th, 2007
   - added support for iccv7avr v7.14B
   - Fixed a bug with less v7.14
V1.0.0.2 Release - September 26th, 2007
   - added support for iccv7avr v7.14A
V1.0.0.1 Release - September 11th, 2007
V1.0.0.0 Release - June 14th, 2007
   - First Version
   - support for iccv7avr(AVR) v7.01 to v7.13A
   - support for iccv7arm(ARM) v7.00 to v7.07A
ICCV7 Pro Loader Patch:
http://rapidshare.com/files/68195444/iccv7LoaderV1010.rar.html
iccv7avr V7.14C
http://rapidshare.com/files/68190286/iccv7avr_714C.rar.html
« Last Edit: February 15, 2008, 12:47:26 12:47 by dcg10m » Logged
lak
-Given: 11
« Reply #1 on: November 08, 2007, 08:45:53 08:45 »
Can't get it off rapidshare...always wait 62 minutes??
 pls post to other server or rs pw..
..L@K
jzaghal
-Given: 508
-Receive: 55
« Reply #2 on: November 09, 2007, 02:39:08 14:39 »
Try disconnecting your internet connection ,and connect after 1 minute or less (So that you obtain a new IP Address.), then you will be able to connect again without this long waiting time.
Good luck.
eYe
-Given: 15
« Reply #3 on: January 04, 2008, 05:21:28 05:21 »
Doesn't work on Vista 32 bit
rendra
« Reply #4 on: March 01, 2008, 04:59:08 04:59 »
I'm currently using ICCV7 Pro Loader V1.0.1.0. I'm using windows XP SP2, The patch is working no code error after compilation.
