April 25, 2026, 05:59:11 17:59
Author Topic: searching for level sensor  (Read 10046 times)
abbas1707
-Given: 15
-Receive: 25
« on: November 04, 2007, 08:40:20 08:40 »
hi,
is there any level sensor available which behaves in same way as LM35 behaves??? i.e it should convert level to voltage as LM35 converts temperature to voltage Sad Sad i have to use it with 8051
any info about such stuff Huh Huh
« Last Edit: November 04, 2007, 08:44:22 08:44 by abbas1707 » Logged
A Thousand Miles Journey Starts With a Single Step
-Given: 405
-Receive: 545
« Reply #1 on: November 04, 2007, 02:50:29 14:50 »
look at this link
http://www.analog.com/en/prod/0,2877,ADXL320,00.html
and here
http://www.mikroe.com/en/tools/accel/
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #2 on: November 04, 2007, 03:05:18 15:05 »
If you could say what kind of level you want to sense ...
Is it water level in a tank , ....., Grain - sand in a Bin Huh? ,.... level - rspsect to horizontal / vertical Huh?
explain a little    Grin
greetings
abbas1707
-Given: 15
-Receive: 25
« Reply #3 on: November 05, 2007, 05:38:59 05:38 »
yeah it is must sense water level in a tank Embarrassed
abbas1707
-Given: 15
-Receive: 25
« Reply #4 on: November 05, 2007, 05:45:06 05:45 »
how can an accelerometer act like level sensor Huh Huh Huh
-Given: 405
-Receive: 545
« Reply #5 on: November 05, 2007, 01:02:13 13:02 »
If you had read the link you would know Huh Huh Huh
Applications:
Cost-sensitive motion- and tilt-sensing applications
Smart hand-held devices
Mobile phones
Sports and health-related devices
PC security and PC peripherals
try this
http://www.uoguelph.ca/~antoon/circ/sensor3.htm
o2
-Given: 41
-Receive: 405
« Reply #6 on: November 07, 2007, 02:54:53 02:54 »
hi,
Hello,abbas
I try to design water tank content regulator
and temperature monitor but i use ATMega 8,herein I utilize sersor level with potensio that at connective with water float
O2
« Last Edit: November 07, 2007, 06:50:27 06:50 by o2 » Logged
abbas1707
-Given: 15
-Receive: 25
« Reply #7 on: November 07, 2007, 03:55:35 15:55 »
yeah i have done it. let me complete the project. then i will share it  Grin Grin Grin
hey o2, my idea is same as yours Wink Wink
« Last Edit: November 07, 2007, 03:59:27 15:59 by abbas1707 » Logged
-Given: 405
-Receive: 545
« Reply #8 on: November 07, 2007, 05:02:01 17:02 »
abbas1707 have a look at Silicon Chip
http://www.siliconchip.com.au/cms/A_109529/article.html
phucthinhel
« Reply #9 on: November 07, 2007, 05:42:45 17:42 »
The level of water in tank which is not stable . Read it is not easy !
« Reply #10 on: November 07, 2007, 08:09:06 20:09 »
For non-contact level measurement try to google "ultrasonic level sesor".
Regards, Ichan.
phucthinhel
« Reply #11 on: November 08, 2007, 12:02:14 12:02 »
When pumping water into tank the lever satble until the pumer finished ! that time they not read accuracy level water when using untralsonic sensor ! that way not so good ...
shailesh5
Translator
-Given: 56
« Reply #12 on: November 08, 2007, 03:18:10 15:18 »
am working in a waste water treatment plant we do use several ultrasonic level sensor from siemens , i can say that i have a stable value when the pumps are pumping or not no fluctuation as these sensor s have an error correction , the model is echomax
shailesh
« Reply #13 on: November 10, 2007, 09:03:31 21:03 »
For a stable measurement, filtering and averaging usually needed.
For example, if an ADC of a microcontroller is used for converting the analog value of the sensor then a simple step to do that is just like:
1. Get some number of samples, let say 10 samples
2. Discard the lowest and highest value
3. Average the values of the rest 8 samples
4. Display the result.
Regards, Ichan.
abbas1707
-Given: 15
-Receive: 25
« Reply #14 on: November 11, 2007, 09:32:57 09:32 »
Regards, Ichan.
i agree, i think we can get stable values in dis way.let me try this Wink
kcwcc
-Given: 37
« Reply #15 on: November 28, 2007, 04:26:33 16:26 »
I have used a pressure sensor as a level sensor as well...this is a common method in industry as well.
o2
-Given: 41
-Receive: 405
« Reply #16 on: December 18, 2007, 08:18:25 08:18 »
Hello abbas1707
this attacment water tank project(tank2.rar) modification from tank.rar with temperature regulator and empty tank button.
O2
bird777
« Reply #17 on: December 18, 2007, 01:42:12 13:42 »
Measure water level:
http://rapidshare.com/files/77412216/foly_magassag.pdf.html
charudatt
-Given: 53
-Receive: 70
« Reply #18 on: December 29, 2007, 04:07:30 04:07 »
Do you have this article ?
-Given: 405
-Receive: 545
« Reply #19 on: December 29, 2007, 03:00:29 15:00 »
charudatt  I'll have to look later and let you know
here ya go should be enough to build it
http://mihd.net/m5zvns
« Last Edit: December 29, 2007, 04:12:24 16:12 by bbarney » Logged
d.barnabe
« Reply #20 on: February 02, 2008, 05:17:35 17:17 »
Hi abbas1707,
I am using ultrasonic level sensors. The name of the sensors are pulsar and Mobrey. This two sensor can convert the water level in current(4-20mA) or in tension(0-10V). These are very good material in my opinion.
See theese sites:
http://www.pulsar-us.com/
http://www.mobrey.com
I hope that this can help you
d.barnabe
