March 08, 2026, 08:48:50 08:48
Pages: 1 2 [3]  All
Author Topic: cc5x  (Read 49135 times)
robban
-Given: 34
-Receive: 38
Warrior
« Reply #50 on: November 13, 2009, 07:01:10 19:01 »
Knudsen compilers have issued a new FREE edition(32k code, no asm-file but hex code) which I enclose together with some useful functions and KCSoft Scintilla IDE:
If You run into problems, pls. feedback. Note: Some of the implementations(like the EEPROM routine) doesn't work using MPLAB_IDE for me, but maybe You have other experience. There are other compatibility issues as well(not clear when to switch between KCSoft-cracked version and Knudsen CC5X v.3.4 Free edition). Hex code size between cracked version and test version is abt. 20%
Code Warrior
kcsoft
-Receive: 68
« Reply #51 on: March 23, 2014, 08:23:44 20:23 »
Patcher for CC5X v3.5 Test Edition.
The test edition generates an incomplete but fully optimized asm file, all labels are named "m000" and does not generate a hex file.
The patcher fixes that and correct labels are generated inside the asm FIle. You still need to compile the asm file using MPASM.
http://www.multiupload.nl/BCAKP0LJIK
FriskyFerretReloaded2
-Given: 233
-Receive: 208
« Reply #52 on: March 24, 2014, 05:15:43 05:15 »
That's a very respectable compiler. Nice post. Did you crack it?
Here's your Sonsivri Pirate Badge if you did.
kcsoft
-Receive: 68
« Reply #53 on: March 24, 2014, 09:23:15 09:23 »
Yep.
Diploma printed!
« Reply #54 on: April 16, 2014, 07:26:26 07:26 »
In your patch, did you fix the 8k code limit?
thanks
ptr
-Given: 17
« Reply #55 on: April 16, 2014, 07:51:52 19:51 »
@kcsoft
do you also have a patcher for CC8E Test Edition?
http://www.bknd.com/cc8etest.exe
Would be very interesting to test this version.
thanks
kcsoft
-Receive: 68
« Reply #56 on: April 17, 2014, 10:45:26 10:45 »
No, I haven't tested/patched anything about the 8k limit. (Lack of free time). Maybe somebody can test this, I don't have any cc5x c program that large in cc5x c dialect to test with. A dummy large c file could be generated for testing.
No, sorry.
I'm not much of a cc5/8 compilers user due to some language limitations, lack of support for Microchip libraries (USB, WiFi, MiWi, external storage/FAT)
bxac
« Reply #57 on: December 23, 2014, 04:27:09 04:27 »
The link for Patcher for CC5X v3.5 Test Edition is not working.
Can you please update it? Thanks
Pages: 1 2 [3]  All
