hamid9543
-Given: 80
« on: December 28, 2005, 05:00:58 17:00 » |
hii want for each count (by opto counter)show lcd decimal count.:cool: start count=0 and end count determine by keyboard. for ex:input keyboard=400 counter count to 400 then stop and show on the lcd thanks for help:confused: :confused:
-Given: 582
« Reply #1 on: December 28, 2005, 05:36:56 17:36 » |
show us some of your code the we may be able to help you can't just expect some one to say here you go mate this is what you want we need more detail that is not a lot to go on wizpic
hamid9543
-Given: 80
« Reply #2 on: December 29, 2005, 11:06:15 11:06 » |
hi step 1) i want by keyboard (14 or 16 key): for ex when i press 450 lcd show "press key =450" step 2) i want micro count with external clock and show conting on the lcd
-Given: 582
« Reply #3 on: December 29, 2005, 11:48:00 11:48 » |
hamid9543
-Given: 80
« Reply #4 on: December 29, 2005, 02:08:52 14:08 » |
hi but i want to use keypad (no pc keyboard).same as keypad of tellephone. thanks for your replay
-Given: 582
« Reply #5 on: December 29, 2005, 02:40:16 14:40 » |
That will be some coding to do that what code have you got so far what about this one http://www.protongeeks.com/index.php?option=com_content&task=view&id=15&Itemid=28 that should give you starting point instead of using the serot command print it onto lcd wizpic
« Reply #6 on: December 29, 2005, 03:16:35 15:16 » |
Hi This can be easily applied using PICBasic Pro, Mikrobasic, or Proton. There are built in functions for 3/4X4 Matrix "Telephone" kepapds in Mikrobasic. Aslo the same applies to Proton using inkey command. If you want to use PICBasic Pro, visit this page, it very outstanding example in deed. I don't see that hamid9543 has specified a specific language to start with, so I assumed basic, unless hamid9543 has some other languages on mind. Let us know what language are you using. Good luck
« Last Edit: December 29, 2005, 03:19:10 15:19 by metal »
-Given: 582
« Reply #7 on: December 29, 2005, 04:02:28 16:02 » |
i think that hamid9543 is trying to do is you enter 450 and it displays 450 the sample page you is like the one i give but as you said Metal it's a good example and a good starting point. by all means it can be done but it will not be easy it all depends on what experance he has got in programming. yes we are here to help but you have got to help yourself first. Metal as you said we can only assume he means basic as he has placed it under baisc forum. i have asked for hamid9543 to give more detail like what PIC and LCD and stuff like that wizpic
« Reply #8 on: December 29, 2005, 04:54:11 16:54 » |
i think that hamid9543 is trying to do is you enter 450 and it displays 450 the sample page you is like the one i give but as you said Metal it's a good example and a good starting point. by all means it can be done but it will not be easy it all depends on what experance he has got in programming. yes we are here to help but you have got to help yourself first. Metal as you said we can only assume he means basic as he has placed it under baisc forum. i have asked for hamid9543 to give more detail like what PIC and LCD and stuff like that wizpic I did not understand this "You have got to help your self first" ??
-Given: 582
« Reply #9 on: December 29, 2005, 06:27:34 18:27 » |
Basicly Metal hamid9543 is not fourth coming with a lot of information i think he is basicly hoping that some one will write the complete code and give it him on a plate. where as i come from some things don't quite work like that. the fun is all about learning. so basicliy the saying i'm willing to help any one who is willing to help them selfs it's a saying us brits use. wizpic
tasosstr
-Given: 96
-Receive: 14
« Reply #10 on: December 29, 2005, 10:13:29 22:13 » |
Hello and from me,
For press 450 in proton you can make (in Proton +)
Device 18F452 XTAL = 4 Dim Key As Byte, i As Byte, KeyFinal As String * 8
Main: Key = InKey Key = LookUp Key,[1,2,3,4,5,6,7,8,9,10,11,12,13,14,15]
Select Case Key Case 0 KeyFinal = KeyFinal + "0" GoSub PrintKeyFinal Case 1 KeyFinal = KeyFinal + "1" GoSub PrintKeyFinal Case 2 KeyFinal = KeyFinal + "2" GoSub PrintKeyFinal Case 3 KeyFinal = KeyFinal + "3" GoSub PrintKeyFinal Case 4 KeyFinal = KeyFinal + "4" GoSub PrintKeyFinal Case 5 KeyFinal = KeyFinal + "5" GoSub PrintKeyFinal Case 6 KeyFinal = KeyFinal + "6" GoSub PrintKeyFinal Case 7 KeyFinal = KeyFinal + "7" GoSub PrintKeyFinal Case 8 KeyFinal = KeyFinal + "8" GoSub PrintKeyFinal Case 9 KeyFinal = KeyFinal + "9" GoSub PrintKeyFinal Case 10 If KeyFinal = "" Then Cls Print At 1,1,"Nothing Selected" DelayMS 1000:Cls GoTo Main EndIf EndSelect
Goto Main
PrintKeyFinal: Cls Print At 1,1,"Pin Selected ",KeyFinal DelayMS 300 Return
Try that and tell me if you have any quastion...
For Count you use the Command PulsIn
Best Regards, Tasosstr
tasosstr
-Given: 96
-Receive: 14
« Reply #11 on: December 29, 2005, 10:19:15 22:19 » |
The sample from Proton+ for Counter Syntax Variable = PULSIN Pin , State
Overview
Change the specified pin to input and measure an input pulse.
Operators
- Variable - a user defined variable of type bit, byte, byte array, word, word array, dword or float.[/size][/font]
- Pin - a Port.Pin constant that specifies the I/O pin to use.
- State - a constant (0 or 1) or name HIGH - LOW that specifies which edge must occur before beginning the measurement.
Example
DIM VAR1 as BYTE Loop: VAR1 = PULSIN PORTB.0 , 1 ' Measure a pulse on pin 0 of PORTB. PRINT Dec VAR1 , " " ' Display the reading GOTO Loop ' Repeat the process.
Notes
Pulsin acts as a fast clock that is triggered by a change in state (0 or 1) on the specified pin. When the state on the pin changes to the state specified, the clock starts counting. When the state on the pin changes again, the clock stops. If the state of the pin doesn't change (even if it is already in the state specified in the Pulsin instruction), the clock won't trigger. Pulsin waits a maximum of 0.65535 seconds for a trigger, then returns with 0 in variable. The variable can be either a word or a byte . If the variable is a word, the value returned by Pulsin can range from 1 to 65535 units. The units are dependant on the frequency of the crystal used. If a 4MHz crystal is used, then each unit is 10us, while a 20MHz crystal produces a unit length of 2us. If the variable is a byte and the crystal is 4MHz, the value returned can range from 1 to 255 units of 10µs. Internally, Pulsin always uses a 16-bit timer. When your program specifies a byte, Pulsin stores the lower 8 bits of the internal counter into it. Pulse widths longer than 2550µs will give false, low readings with a byte variable. For example, a 2560µs pulse returns a reading of 256 with a word variable and 0 with a byte variable.
See Also COUNTER PULSOUT
hamid9543
-Given: 80
« Reply #12 on: December 30, 2005, 07:21:03 07:21 » |
thanks thanks thanks plaese excusme ! i am amator in pic program i using pic basic pro and hardware is 16f876 metal i visit your link but micro code studio not compil this program( 4 error). i explain about my project by example: example1) i press "5" then "3" then "3" then "#" lcd show press key is "533" example 2) i press "2" then "1" then "#" lcd show press key is "21" step 2)when show lcd what key pressed counter count to pressed key please read below example: i press 320 on key pad : lcd shown press key is "320" and then counter count to "320" (clock for counter make by opto counter in external pic) tasosster i using pic basic pro no proton thanks for your help
-Given: 582
« Reply #13 on: December 30, 2005, 09:27:31 09:27 » |
hamid9543 i understand more now what your teying to do is this a timer you want to create? i have code for timer where you use a pot(dial) to set time and then press btuuon and it times down it can be set to time up is this the type of thing you are trying to do ? wizpic
hamid9543
-Given: 80
« Reply #14 on: December 30, 2005, 08:04:31 20:04 » |
hi metal i explain this project again for you ,clearly i try to design project that: step 1) lcd shows the number that i press in keypad(for example: 412 or 21 or 9 or etc...) step 2) and then timer count from "0" until this number step 3) and then output become high(output is led) mention::: the clock for timer provid by external source ( for example : optocounter)
« Reply #15 on: December 31, 2005, 10:24:35 22:24 » |
Hamid,
No need to explain any thing for me, or other members. As Wizpic said, help is given to those who are willing to help their selves first, unfortunately, wizpic didn't know how to say it the right way, he might be suffering with the right english syntax !!
Any way, instead of asking others to serve you a code on a plate, you better start reading about registers of the PIC MCU you are using, and try to know what each one does, no need to read about PCLATH, start from status register, as this will help you find out how registers control the operation of PIC a Little bit.
Another thing, read the manual of the compiler you are using, that very important for your first project with PIC MCUs.
Of course, as soon as I see the first portion of your OWN code, I will be happy to giude you, as well as other members here on the forum.
MetaL
hamid9543
-Given: 80
« Reply #16 on: January 01, 2006, 10:54:22 10:54 » |
thanks metal you guide me very much
