April 27, 2026, 12:26:02 12:26
Author Topic: RTOS choice for PIC24/dsPIC  (Read 10184 times)
lucicop
« on: September 27, 2007, 09:12:43 09:12 »
Do you know if they have released this ? Does any of you have it ? Thanks !
Lucian
« Last Edit: September 28, 2007, 10:23:08 10:23 by lucicop » Logged
lucicop
« Reply #1 on: September 28, 2007, 10:22:33 10:22 »
I see no one knows anything about this. On the Hi-Tech forums too it is the same silence. I guess this combination is not used. I think I will switch to MPLAB C30 compiler, and for that there are more options for an RTOS. I would like to discuss with you what you are using as an RTOS if you are using PIC24/dsPIC devices.
bluex
-Receive: 39
« Reply #2 on: September 29, 2007, 10:11:55 10:11 »
have a look to www.picos18.com they have an RTOS for PIC18 and a version for PIC24/dsPIC. and it's open sources with multiple drivers.
jezo
-Given: 53
« Reply #3 on: October 01, 2007, 07:46:34 07:46 »
Hi, I use uC/OS-II with dsPIC33FJ256GP710 and MPLAB C30. I'm very satisfied. RTOS viewer from MPLAB supports this OS, but still better is uC/OS-View. With this property you will see,  what is happening in real time.
lucicop
« Reply #4 on: October 01, 2007, 01:01:11 13:01 »
Thanks for the replies. I have formed my oppinion and I plan to use uCosII too, with C30 compiler. It is similar to Salvo in naming conventions and I like that. It is very different from Salvo in the fact that is preemptive, and so the applications will need to be redesigned in order to be ported.
micropar
-Given: 44
« Reply #5 on: October 03, 2007, 03:30:20 03:30 »
Hi lucicop and jezo,
From where did downloaded ucOS-II for PIC18?
Thanks in advance for sharing,
--micropar--
jezo
-Given: 53
« Reply #6 on: October 03, 2007, 05:51:47 05:51 »
uC/OS need work with stack (every one task has a self stack space). PIC18 hasn't real stack, only for storing calls. For this  processor you can try Salvo.
lucicop
« Reply #7 on: October 03, 2007, 06:12:43 06:12 »
I plan to use uCos/II with PIC24, and it exists a uCos port for this processor. uCos has the source publicly available on www.micrium.com .
mlgamy
« Reply #8 on: October 22, 2007, 07:18:23 19:18 »
   there is also the TNKernel ( http://www.tnkernel.com/port_dsPIC.html ) which open source.
   extract from the website :
  "TNKernel performs a preemptive priority-based scheduling and a round-robin scheduling for the tasks with identical priority. The current version of TNKernel includes semaphores, mutexes, data queues, event flags and fixed-sized memory pools. The system functions calls in the interrupts are supported."
   the list of feature seem very comprehensive but i haven't use it.
   is everyone have already use it ?
MirceaI
« Reply #9 on: December 12, 2007, 06:15:11 06:15 »
you can try here: www.freertos.org
there is pic24/dsPic port.
