need help to converting BCD data - Sonsivri
You think I am funny guy huh?
May 14, 2026, 11:35:24 11:35
Author Topic: need help to converting BCD data  (Read 6474 times)
sohel
-Given: 169
-Receive: 149
« on: March 11, 2014, 02:50:59 02:50 »
Dear all,
I am working on countdown timer with RTC ds12887 and at89s51. RTC give me sec value in BCD format.
MOV A,#00H        ;READ SECONDS
LCALL READ_RTC
MOV 40H,A                    ;Store sec Value
how can i convert in reverse like that
00 to 00
01 to 59
02 to 58
03 to 57
04 to 56
..... continue to 00 to 00
Regard's
 Cry
« Last Edit: March 11, 2014, 02:54:24 02:54 by sohel » Logged
FriskyFerretReloaded2
-Given: 233
-Receive: 208
« Reply #1 on: March 11, 2014, 04:41:23 04:41 »
Did you want help with the algorithm or did you want someone to write the 8051 assembler code for you?
TucoRamirez
-Given: 257
-Receive: 115
« Reply #2 on: March 11, 2014, 04:43:22 04:43 »
implement if readvalue= 0  then readvalue=60 and do ( 60 - var) ... otherwise lazy fuctard solution could be     "create a lut organized backwards :p "
« Last Edit: March 11, 2014, 11:38:39 11:38 by TucoRamirez » Logged
« Reply #3 on: March 11, 2014, 06:59:36 06:59 »
Why do you need to count down?
What are you doing with the result?
Is it always the same period?
Not enough info on the application - you may be trying to do something you don't  have to, or there may be a shortcut using BCD ADDITION and a RTC compare
@tucoramirez - that wasn't a very nice thing to say
"lazy fuctard solution"
 Grin
hate
-Given: 156
-Receive: 355
« Reply #4 on: March 11, 2014, 10:22:11 10:22 »
LCALL READ_RTC
RR A        ; Rotate A to the right 4 times
RR A
RR A
RR A
ANL A, #0Fh        ; Get low nibble
MOV B, #0Ah       ; Load decimal 10 into B
MUL AB               ; Multiply A and B
MOV R0, A           ; Save A to R0
MOV A, 40h         ; Load BCD again
ADD A, R0           ; Add (high nibble *10) to low nibble namely A=high*10+low
Accumulator 'A' will have your BCD converted to binary. You can then do whatever you want with it. I'm rusty with 8051 assembler so the code might not work but I think you got the idea.
Regards...
sohel
-Given: 169
-Receive: 149
« Reply #5 on: March 11, 2014, 10:33:01 10:33 »
Thanks to all,
i want to implement this calculation, result should be BCD.
60 - 01 = 59
99 - 01 = 98
98 + 60 = 158
158 - 99 = 59
hate
-Given: 156
-Receive: 355
« Reply #6 on: March 11, 2014, 11:04:36 11:04 »
I still don't get what you're trying to achieve!
Thanks to all,
60 - 01 = 59
99 - 01 = 98
98 + 60 = 158
158 - 99 = 59
Which of these numbers come in BCD? All? None? Some, which ones? Do you only need to convert the results to BCD? If the latter, check the thread below that has an example code which converts binary to BCD. Or be more clear pls.
Regards...
bigtoy
-Given: 365
-Receive: 297
« Reply #7 on: March 23, 2014, 01:52:39 01:52 »
If you have the room, use a look-up table. For an 8-bit number the table would be 256 bytes long.
