April 27, 2026, 08:03:23 20:03
Author Topic: ARM Parallel Port Programmer Problem not detecting the target??  (Read 5905 times)
xpress_embedo
-Given: 122
-Receive: 254
« on: January 28, 2014, 05:10:09 05:10 »
Helllo!!! Everyone i am using this Parallel Port Programmer
http://shop.ngxtechnologies.com/prod...products_id=29
to program my LPC2148, it is a Wiggler Based Programmer and is supported by H-JTAG Software.
I tried to use this programmer with Keil Directly, but failed because i had not started H-JTAG Server, after that i started H-JTAG Server and my Controller gets detected as ARM7TDMI-S microcontroller in H-JTAG Server, after that i open H-Flasher and then program a simple code to blink LED's.
Its programs and verify properly but LED's on board doesn't work but when i reset the board by reinserting its power it works.
But after that H-JTAG Server is not able to detect the target, i dont know why??
Its works for the first time and till now it is not detecting target and giving this error.
Even if i didn't connect the hardware its giving the same error.
Please suggest me what might be the problem.
