May 28, 2025, 06:03:54 06:03
Author Topic: Altium Export Gerbers  (Read 5839 times)
diamadiss
-Given: 202
« on: December 11, 2013, 10:52:29 22:52 »
Hello,
When I am going to save my gerber files in altium always shows me a window with a tab "Gerber Export Settings" (picture 2). Does anyone knows what exactly are digits and which are serving. Thanks.
CocaCola
-Given: 170
-Receive: 232
« Reply #1 on: December 11, 2013, 11:33:38 23:33 »
I don't quite understand what you are asking...
The settings you refer to are how accurate you want to output to be, do you want .01 , .001 or .0001 resolution?  Due note that chances are most PC board manufactures are not going to go beyond .01 (metric) or .001 (imperial) in most applications...
If you have a specific board company you use, they would be the one to contact in regards to their preferred output, although most are pretty flexible nowadays...
diamadiss
-Given: 202
« Reply #2 on: December 12, 2013, 07:10:43 07:10 »
In the first picture is the accuracy but in the second picture what are the digits (integer 3 - decimal 2)?
oxygen007m
-Given: 397
-Receive: 71
« Reply #3 on: December 12, 2013, 07:13:22 07:13 »
Actually you don't need to change default setting , because most of gerber viewers or cam /cad processors are able to auto recognize different settings . Just select the layers to be plotted in gerber format and leave the rest to cam tool . I personally prefer ODB+ because it is full compatible with all cam processors and you don't need to worry about settings .
diamadiss
-Given: 202
« Reply #4 on: December 12, 2013, 02:23:07 14:23 »
Ok. Thanks for your answer.
