April 13, 2026, 11:59:39 11:59
Author Topic: Semiconductor analyzer - request  (Read 14065 times)
dandumit
« on: September 19, 2007, 02:23:37 14:23 »
Does anyone has documentation about Semiconductor Analyzer like :
http://www.m3electronix.com/features.html
or
http://www.mwinstruments.com/AS4002/AS4002_f.html
the first product seems to be better.
10x
DD
dezso
-Given: 34
-Receive: 137
« Reply #1 on: September 20, 2007, 04:02:53 04:02 »
Here is it.
Need to find firmware for it.
http://rapidshare.com/files/56914129/sa.pdf.html
dezso:
dandumit
« Reply #2 on: September 20, 2007, 09:01:56 09:01 »
That's only the documentation from the site. Is the same thing as :
http://www.mwinstruments.com/AS4002/AS4002_assembly_f.pdf
Firmware is needed ! By the way, is any chance to read the firmware from pic even it has the protection bites set ?
pl4tonas
-Given: 330
-Receive: 196
« Reply #3 on: September 20, 2007, 11:19:17 11:19 »
If it is copy protected, protection byte set, there is no way to read it.
dezso
-Given: 34
-Receive: 137
« Reply #4 on: September 20, 2007, 09:44:58 21:44 »
or
10x
DD
Hey kid this is what you asked for  Cheesy
dezso:
sacoroxo
-Given: 34
-Receive: 26
« Reply #5 on: September 21, 2007, 12:20:30 00:20 »
I have this one ( http://www.elektor.com/magazines/2005/april/sc-analyser-2005.57517.lynkx ), from Elektor and it works very well.
Here ( http://www.4shared.com/file/24701676/e086b986/SC-ANALYSER-2005.html ) you can download the schematic and the firmware.
ipek
-Given: 60
-Receive: 79
« Reply #6 on: September 21, 2007, 02:46:03 02:46 »
Look france magazin open source pin to pin elector schematic diagram
http://rapidshare.com/files/57127317/Eprat_Transistor_tester.rar.html
16f870 dont wory 873 and 876 make it check ok...
elektor darlington no display
          base biased tr no display example dtc124 dta114 etc...
          trystor and triac no display and final bad report zener diode no display...
ffr58kk90
-Given: 149
« Reply #7 on: September 23, 2007, 12:46:32 12:46 »
Excellent project, does anyone have a good quality scan of the elektor article, particularly the pcb layout.
It would be good to attempt to make up a pcb from the artwork scan.
It was in the April 2005 Elektor but the rapidshare copy is not sharp enough to print an artwork from
Anyone?
Ffr
dezso
-Given: 34
-Receive: 137
« Reply #8 on: September 24, 2007, 02:57:11 02:57 »
Here it is.
The original.
dezso:
localcrack
-Receive: 21
« Reply #9 on: November 24, 2007, 09:34:55 21:34 »
I require firmware for this project
dezso
-Given: 34
-Receive: 137
« Reply #10 on: November 25, 2007, 12:15:42 00:15 »
Here is the code for the Elektor version...
dezso:
building
« Reply #11 on: November 28, 2007, 08:27:44 08:27 »
What is you want in semiconductor analyzer? ect. analyzer transistor? or analyzer mosfet? or analyzer circuit? I don't understand you question.  Cool
ta2ctp
« Reply #12 on: February 24, 2011, 04:22:05 16:22 »
Hi friends,
 I did this circuit assembly.
However, the PIC can not upload the hex file. Line 1025 is an error !! . .
Waiting for help if you have friends who managed the installation.
Best Regards
Safak.
-Receive: 4459
« Reply #13 on: February 24, 2011, 05:10:56 17:10 »
Hi friends,
Best Regards
Safak.
With  it being a Elektor project, I would say check to see if any errors were reported in the few months after April 2005.
Looking at the project pages the only thing I could see, that may cause problems is the configuration fro the programer.
osc = RC mode, wdt = off and so on, get this wrong and you may get the error reported by you.
You could check this project out in proteus, also you could have supplied some more infomation, as to programmer, and what files you tried.
Use search for >> SCA2005 or just goto
http://www.sonsivri.com/forum/index.php?topic=1565.0
« Last Edit: February 27, 2011, 08:02:50 20:02 by pickit2 » Logged
raidera
« Reply #14 on: April 30, 2011, 07:00:30 07:00 »
Here is another circuit http://www.mikrocontroller.net/articles/AVR-Transistortester in German. I test it, works fine and accurate!
There is everything: Circuit, PCB, Firmware. In forum of the site for that topic have newer firmwares and PCBs.
th_sak
-Given: 150
-Receive: 149
« Reply #15 on: April 30, 2011, 08:08:16 08:08 »
Hi, have a look at my project (copy from mikrocontroller.net). Read at the video description!
http://www.youtube.com/watch?v=dtoSCx3pwpY
iphone
-Given: 115
« Reply #16 on: April 30, 2011, 05:01:46 17:01 »
Hi. very good project.
Can you share the project over here? I would like to make it as tester for my electronic components.
NOTE: Is it use PIC or Atmel or what microcontroller ?
titi
-Given: 4121
-Receive: 834
« Reply #17 on: April 30, 2011, 07:11:48 19:11 »
It is using a ATMEGA8.
You can find more information at :
http://www.mikrocontroller.net/topic/131804 in dutch.
Best regards.
« Last Edit: May 01, 2011, 08:38:36 08:38 by titi » Logged
raidera
« Reply #18 on: April 30, 2011, 07:46:15 19:46 »
All necessary files about project from mikrocontroller.net can be found here http://frickelpower.bplaced.net/ctest/
There are several languages and contents to download.
Works fine with all supported components!
dideco
« Reply #19 on: May 01, 2011, 12:54:34 12:54 »
It  is possible to download a compressed file from http://frickelpower.bplaced.net/ctest/ .
But there seems a problem when you try to open file. There is an "unexpected end of file" error. The downladed file is corrupted and does not contain any *.hex file.
Regards...
« Last Edit: May 01, 2011, 01:15:08 13:15 by dideco » Logged
raidera
« Reply #20 on: May 01, 2011, 08:23:09 20:23 »
I downloaded it and everything is fine, try the attachment it is identical to that of http://frickelpower.bplaced.net/ctest/
dideco
« Reply #21 on: May 01, 2011, 09:42:06 21:42 »
Hi everybody,
Both of us are correct.
If I use Internet Explorer 8 using Windows XP, probably due to some settings, I download file but cannot open it.
I I use Google Chrome, everything is OK and can download and unzip all the files without any error.
iphone
-Given: 115
« Reply #22 on: May 02, 2011, 04:04:25 16:04 »
Is there this tool using PIC? Is there any PIC base ?
It's hard for me to use atmel ... expensive, hard to get sample ( maybe imposible, tried many time but just waste my time)
Tq.
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #23 on: May 17, 2011, 01:26:35 13:26 »
You can try to port the ATMEL code to PIC. Since it's in C-code it should be very simple.
Just the basic hardware functions must be replaced by those of the PIC controller.
