May 22, 2025, 09:25:09 09:25
Author Topic: +/- dual adjustable power supply help  (Read 5266 times)
MAXPAYNE
-Given: 502
-Receive: 368
It's a little funny......
« on: September 18, 2007, 06:37:40 06:37 »
I have found a ckt diagram for adjustable dual power supply at http://sound.westhost.com/project44.htm
but i didn't found the lm337 ic in the market.
Is there any alternative  or any other ckt diagram for at least 1A output u know?
Please help!
Thanks in advance Sad Sad
Whats the Craziest Project u have done lately...?
bbarney
-Given: 405
-Receive: 545
« Reply #1 on: September 18, 2007, 07:10:28 07:10 »
I don't think you looked very hard Grin
http://search.digikey.com/scripts/DkSearch/dksus.dll
http://www.futurlec.com/cgi-bin/search/search.cgi
http://uk.farnell.com/jsp/search/browse.jsp?N=411+1000108&Ntk=gensearch_001&Ntt=lm337&Ntx=
ipek
-Given: 60
-Receive: 79
« Reply #2 on: September 18, 2007, 11:44:17 11:44 »
www.fairchildsemi.com
RC4194
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #3 on: September 18, 2007, 12:40:22 12:40 »
I don't have any opprtunity to do transaction on internet and have to rely only on the local market for elec parts.
Please help me with alternative or another diagram. Crying need for my lab power supply....... Sad Sad Sad
bbarney
-Given: 405
-Receive: 545
« Reply #4 on: September 18, 2007, 06:23:56 18:23 »
your local supplier should be able to order the parts as it's a common as part as they get
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #5 on: September 19, 2007, 05:19:38 05:19 »
I already checked them. They didn't...... Undecided Undecided
rf151
« Reply #6 on: December 16, 2007, 01:52:45 13:52 »
u can use lm317 and lm137/237/337  with together for doual adjustable power supply or use 7805 and 7905 with together with a knob potansiometer between GND pin and ground.
but your minimum voltage limit in +/_ 5.( lm317/lm337 limit is 1.2 volt) . u can find the circuit in 7805 datasheet.
titi
-Given: 3923
-Receive: 834
« Reply #7 on: December 16, 2007, 04:32:07 16:32 »
Hello,
if your transformer has two insulated winding on the secondary, you can make 2 positives power supply with LM317, you need 1 diodes bridges more.
you connect le + of the second power supply to the gnd of the first one and you have symetrical power supply.
Here a small drawing to explain that on attachement.
Bye.
« Last Edit: December 16, 2007, 04:39:27 16:39 by titi » Logged
Trishool
« Reply #8 on: December 17, 2007, 08:36:09 08:36 »
Please help!
MAXPAYNE , The regulator LM337 is very reliable type , Alternative would be 555 timer type ckts to generate -ve supply , but not reliable at all.
Ts
Ts
« Last Edit: December 17, 2007, 08:39:56 08:39 by Trishool » Logged
