hate
-Given: 156
-Receive: 355
« Reply #25 on: July 30, 2013, 01:38:32 13:38 » |
Following macro not works on CCS 5.008
#define bit_toggle(var,bit) ((var&(1<<bit))!=0) ? (var &= ~(1<<bit)) : (var |= (1<<bit))
However it perfectly works on CCS 4.xxx
is anything is wrong ?
Btw I realized there is no semicolon [;] at the end of the macro, you might be missing it when you are using the macro which may also be the reason why it doesn't work.
Regards...
hock
-Receive: 126
« Reply #26 on: August 01, 2013, 01:07:09 13:07 » |
can some one please post a non mega.co.nz link for ver 5.010 hock
duende_azul
-Given: 126
-Receive: 1262
« Reply #27 on: August 11, 2013, 05:07:26 17:07 » |
Never ending history  Version 5.011
« Last Edit: July 22, 2015, 11:07:04 23:07 by duende_azul »
Old_but_Alive
-Given: 839
-Receive: 122
« Reply #28 on: August 11, 2013, 05:30:59 17:30 » |
its a journey, not a destination
duende_azul
-Given: 126
-Receive: 1262
« Reply #29 on: September 13, 2013, 03:13:12 15:13 » |
New version 5.012
« Last Edit: July 22, 2015, 11:16:45 23:16 by duende_azul »
electrocutioner
« Reply #30 on: September 13, 2013, 10:20:40 22:20 » |
Hello All,
Could someone check an issue for me? choose one of the default colors in the editor properties which has a dark background -- Classic or Twilight. Then load a file into the editor and right click its tab. Choose New Edit Window. In the new window, are the colors in tact? or are they infused with white background? I am asking to see if it is a true bug or an issue with my PC. Thanks!
Magnox
-Given: 1005
-Receive: 285
Oink!
« Reply #31 on: September 13, 2013, 10:40:23 22:40 » |
Same here - I get a mostly white background in the new edit window, with some bits in black. Bug!
hock
-Receive: 126
« Reply #32 on: September 17, 2013, 05:07:22 05:07 » |
i am not able to use ver 5.011 and 5.012 with the keygen. i get the message that the license file is currept. has some one else fased the same issue?
hock
Magnox
-Given: 1005
-Receive: 285
Oink!
« Reply #33 on: September 17, 2013, 07:57:35 07:57 » |
I've never used a keygen, just copied the license files that I've had for years. Same ones as somewhere above in the thread probably.
However, I've just tried one of the keygens I have downloaded to generate new license files. It seemed to work for 5.012. No complaints about the files, and the 'about' box showed CCS licensed as expected. That was with a clean install on Windows XP SP3 if it makes any difference.
The keygen that I tried is called SCG-PCWHD-keygen and it is 10kB.
hock
-Receive: 126
« Reply #34 on: September 17, 2013, 06:06:29 18:06 » |
i am using the same one, it was uploaded in ccs 4 at post 71. when i try to pass the new license file after install it give erroe. it use to work fine for up to ver 5.010. now it is not working. let me try a fresh install.
mplab complains about a dll erro and exits.
this is the error message from mplab ide 8.92 works fine with ver 5.010 Error 44 "##################.c" Line 1(1,1): Internal Error - Contact CCS PR-CODE ############## hock
« Last Edit: September 17, 2013, 07:30:12 19:30 by hock »
avrtopic
-Given: 38
« Reply #35 on: October 12, 2013, 12:41:55 00:41 » |
Has a solution been found for the license file issue under 5.012? I am having the same problem, using license files I have had for a long time. Running the keygen yields the same results.
OrciBorg
-Given: 106
« Reply #36 on: October 24, 2013, 11:25:43 11:25 » |
Version 5.013 has been released and fixes a problem with printf disabling interrupts on some parts.
duende_azul
-Given: 126
-Receive: 1262
« Reply #37 on: October 29, 2013, 11:30:16 23:30 » |
New bugs update.  CCS 5.013
« Last Edit: July 22, 2015, 11:17:29 23:17 by duende_azul »
mitsos
-Given: 3306
-Receive: 5284
« Reply #38 on: November 01, 2013, 03:34:59 15:34 » |
hi
if someone here working the version 5 of pcwhd in the mpabx environment please share with us how to do that. In my place the official mpabx plugin make nothing.
regards mitsos
gonzogonzo
-Given: 79
-Receive: 49
« Reply #39 on: November 02, 2013, 06:21:51 18:21 » |
For me is working; Simply create project with CCS wizard, create project with Mplabx wizard (sure that use CCS plugin) and than add Your C File (from CCS) to Source file into mplabx project than compile: all ok (also proteus vsm)....
hock
-Receive: 126
« Reply #40 on: November 05, 2013, 07:00:46 07:00 » |
to mitsos Please install MPLABX as well as CCS in folders without space. go to MPLABX > tools> plugins> updates look for ccs c compiler. select and install you must be connected to net. now ccs is integrated with your MPLABX
please let me know if it works for you. working for me.
mitsos
-Given: 3306
-Receive: 5284
« Reply #41 on: November 05, 2013, 11:29:14 11:29 » |
hi
I confirm that hock, share with us the solution to integrate successfully the ccs compiler to mplabx.
regards mitsos
« Reply #42 on: November 05, 2013, 01:25:48 13:25 » |
hi
regards mitsos
the first result in google search for ccs 5 mplabx: http://www.ccsinfo.com/pdfs/mplabx_ccs_tutorial.pdfand I remember this one worked for me...
duende_azul
-Given: 126
-Receive: 1262
« Reply #43 on: November 13, 2013, 09:03:58 21:03 » |
CCS 5.015
« Last Edit: July 22, 2015, 11:18:11 23:18 by duende_azul »
microchip
-Receive: 16
« Reply #44 on: December 21, 2013, 01:20:48 01:20 » |
Has anyone else got the RapidUSB prototyping tool from CCS? I picked one up for $20 but I can't get it to program - the manual says to look for "RapidUSB Loader" under program, but all I get are E3 USB, Bootloader, and ICD.
gan_canny
-Given: 101
-Receive: 26
« Reply #45 on: January 18, 2014, 02:47:44 14:47 » |
Any chance of an update to the latest version 5.017 ?
duende_azul
-Given: 126
-Receive: 1262
« Reply #46 on: January 21, 2014, 02:42:09 02:42 » |
Here: CCS 5.017
« Last Edit: July 22, 2015, 11:18:58 23:18 by duende_azul »
JackalImm
Online
-Given: 85
-Receive: 54
« Reply #47 on: January 21, 2014, 02:56:10 02:56 » |
hi duende_azul, can you share the password of the RAR file?  Thnx
XxMohannadxX
-Given: 23
-Receive: 78
« Reply #48 on: January 22, 2014, 11:36:13 11:36 » |
hi i try the default forum password but i dos not work  what is the correct password??
duende_azul
-Given: 126
-Receive: 1262
« Reply #49 on: January 24, 2014, 02:43:11 14:43 » |
Sorry guys  ... new link without password...
« Last Edit: July 22, 2015, 11:19:48 23:19 by duende_azul »
