December 03, 2025, 12:00:14 00:00
Author Topic: Four-channel temperature controller  (Read 8241 times)
Catcatcat
-Given: 308
-Receive: 1822
« on: April 24, 2013, 04:39:49 16:39 »
I bring to your attention a project to study the work with temperature sensors DS18b20 and how the finished design.
Four independent channels of temperature control, can simultaneously connect 16 temperature sensors DS18B20 with the removal of up to three hundred meters. You can choose to adjust the sensor is connected to the device. Each channel can operate in either heating or cooling mode. The range of temperature control up to 125.0 -55.0 Celsius. The controller for temperature measurement uses a library ds18b20.h. Library performs all functions related to servicing network of 16 sensors, as well as the ability to add and replace if necessary damaged. To display the library indic_4led.h. The minimum number of parts used.
Implementation project in MPLAB IDE v8.90, MPLAB XC8 C Compiler V1.12.
The project is in the attachment. If you have any questions do not hesitate to ask. Additional description can be read on my website
Old_but_Alive
-Given: 804
-Receive: 122
« Reply #1 on: April 24, 2013, 04:58:30 16:58 »
excellent, a very nice project.
thanks for sharing it
« Reply #2 on: April 25, 2013, 03:33:58 03:33 »
Write it up for Nuts and Volts - they'll pay you for it
puta
-Given: 377
-Receive: 29
« Reply #3 on: April 26, 2013, 10:51:35 10:51 »
Awesome..!
Good work Mate  !!!
« Reply #4 on: April 26, 2013, 12:03:57 12:03 »
Do you have PCBs to sell?
Catcatcat
-Given: 308
-Receive: 1822
« Reply #5 on: April 26, 2013, 02:34:26 14:34 »
There is an option PCB format PCAD-2006 and Gerber, which option would suit?
Old_but_Alive
-Given: 804
-Receive: 122
« Reply #6 on: April 26, 2013, 04:30:20 16:30 »
i would also be interested in a couple of bare pcb,s
« Reply #7 on: April 26, 2013, 05:07:54 17:07 »
I did not mean I wanted to make those PCBs.
I want ready PCBs.
If we can setup a group buy for PCBs and components, we can get them for cheap.
Catcatcat
-Given: 308
-Receive: 1822
« Reply #8 on: April 26, 2013, 06:47:28 18:47 »
Purchased from the Ukraine, several printed circuit boards, I think it is useless. I ordered their production in China, there are easier and cheaper to manufacture. If necessary I can help make order, and you will pay and receive. In an attachment, Gerber files from writing to order production. Just a word of caution, it is a universal circuit board is designed for multiple devices.
Posted on: April 26, 2013, 07:35:57 19:35 - Automerged
It is a complete circuit diagram of the PCB
« Reply #9 on: April 26, 2013, 07:13:19 19:13 »
Ok, how much does it cost for each PCB.
Catcatcat
-Given: 308
-Receive: 1822
« Reply #10 on: April 26, 2013, 09:34:12 21:34 »
Printed circuit board itself is inexpensive, the cost of expensive pre-production and transportation costs. The more order, the cheaper the cost per unit. I can link you to the manufacturer, and they will be given to you an invoice.
On the number of 200 units, the cost turned in $ 0.7
« Last Edit: April 26, 2013, 09:38:58 21:38 by Catcatcat » Logged
sohel
-Given: 169
-Receive: 149
« Reply #11 on: April 28, 2013, 05:37:05 05:37 »
compiler error,
anyone have proteus simulation?
"HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode)  V9.83
Copyright (C) 2011 Microchip Technology Inc.
Serial number: HCPICP-654321 (PRO)
Warning [1090] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\main.c; 86. variable "_telefon" is not used
Warning [1090] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\ds18b20.h; 48. variable "_coldachu" is not used
Warning [1090] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\ds18b20.h; 49. variable "_naydendatch" is not used
Warning [1090] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\main.c; 111. variable "_poslsim" is not used
Warning [1090] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\main.c; 111. variable "_teleaddr" is not used
Error   [223] E:\Four-channel temperature controller\ch4010-v16.catcatcat_2\main.c; 55. digit out of range
********** Build failed! **********
Catcatcat
-Given: 308
-Receive: 1822
« Reply #12 on: April 28, 2013, 07:19:47 07:19 »
Use the MPLAB XC8:
Microchip MPLAB XC8 C Compiler V1.12
Copyright (C) 2012 Microchip Technology Inc.
License type: w
Memory Summary:
    Program space        used  19C8h (  6600) of  2000h words   ( 80.6%)
    Data space           used    B2h (   178) of   400h bytes   ( 17.4%)
    EEPROM space         used    48h (    72) of   100h bytes   ( 28.1%)
    Configuration bits   used     2h (     2) of     2h words   (100.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
Loaded C:\Proekt_MPLAB\_illissi\_ch_4000_termoreg\ch_4000_termoreg.cof.
********** Build successful! **********
sohel
-Given: 169
-Receive: 149
« Reply #13 on: April 28, 2013, 07:51:43 07:51 »
thanks
i have to study mplabx, i am new about it. Grin
Catcatcat
-Given: 308
-Receive: 1822
« Reply #14 on: April 28, 2013, 08:19:41 08:19 »
project can easily be transferred to MPLABX
check here working in this environment:
License type: w
Memory Summary:
make[2]: Leaving directory `C:/Proekt_MPLABX/_ch_4000_termoreg/ch_4000_termoreg.X'
make[1]: Leaving directory `C:/Proekt_MPLABX/_ch_4000_termoreg/ch_4000_termoreg.X'
BUILD SUCCESSFUL (total time: 19s)
Loading code from C:/Proekt_MPLABX/_ch_4000_termoreg/ch_4000_termoreg.X/dist/default/production/ch_4000_termoreg.X.production.hex...
Loading symbols from C:/Proekt_MPLABX/_ch_4000_termoreg/ch_4000_termoreg.X/dist/default/production/ch_4000_termoreg.X.production.cof...
Loading completed
If difficulties arise I can fill in for the draft forum for MPLABX
sohel
-Given: 169
-Receive: 149
« Reply #15 on: April 28, 2013, 11:41:58 11:41 »
 Grin now i am going to new world with mplabx.
Thanks Again.
main.c:86: warning: variable "_telefon" is not used
ds18b20.h:48: warning: variable "_coldachu" is not used
ds18b20.h:49: warning: variable "_naydendatch" is not used
main.c:111: warning: variable "_poslsim" is not used
main.c:111: warning: variable "_teleaddr" is not used
Memory Summary:
    Program space        used  13E4h (  5092) of  2000h words   ( 62.2%)
    Data space           used    78h (   120) of   400h bytes   ( 11.7%)
    EEPROM space         used    28h (    40) of   100h bytes   ( 15.6%)
make[2]: Leaving directory `C:/Documents and Settings/Administrator/MPLABXProjects/new.X'
make[1]: Leaving directory `C:/Documents and Settings/Administrator/MPLABXProjects/new.X'
BUILD SUCCESSFUL (total time: 14s)
Loading code from C:/Documents and Settings/Administrator/MPLABXProjects/new.X/dist/default/production/new.X.production.hex...
Loading symbols from C:/Documents and Settings/Administrator/MPLABXProjects/new.X/dist/default/production/new.X.production.cof...
Loading completed
Catcatcat
-Given: 308
-Receive: 1822
« Reply #16 on: April 28, 2013, 01:52:15 13:52 »
I was interested in these figures
I
Memory Summary:
and sohel
Memory Summary:
sohel
-Given: 169
-Receive: 149
« Reply #17 on: April 28, 2013, 02:10:34 14:10 »
i was trying to simulate with proteus, compile file included.
