You think I am funny guy huh?
April 09, 2026, 11:40:55 11:40
Author Topic: proton and interrupts (RB0) ... i have problems  (Read 21861 times)
jeanninemtv
-Given: 57
-Receive: 25
« on: December 13, 2005, 11:13:23 23:13 »
hi, i'm making a little program on a 16f84a
an lcd working in 4 bit mode, 3 buttons:   ra1  ra2  and rb0
the lcd works on rb4...rb7  / rb3 rb2 ctrl lines
i select an time interval from 0 to 1000 ms
it shows that time on the lcd
and when i press rb0 it shots only a pulse with the specified duration.  ___|---|_
the problem is the following.
i run the bas on proteus and  i set up the "width " of the single pulse , the loop works ...
i press rb0
and the one shot pulse goes ok!!!
but
when pic returns from interrupt
it goes to hell
gets out of mainloop...
 Sad
:mad:  and when i press again rb0 .... it shots ok
but never returns to mainloop.
can anyone share any proton picbasic example code with RB0 ....?
please.
next thread i 'll put the code, and dsn files ...
thanks my friends
-Given: 582
« Reply #1 on: December 13, 2005, 11:16:46 23:16 »
show us your stuff we might be able to help show some sample of code
i might be able to help
wizpic
jeanninemtv
-Given: 57
-Receive: 25
« Reply #2 on: December 14, 2005, 01:47:03 01:47 »
hello.  i need to back to the main loop when the interrupt subroutine ends ...
note for :  i canot upload filess :confused:
i press upload button and appears
Forbidden
You don't have permission to access /forum/newattachment.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.34 Server at http://www.sonsivri.com Port 80
-Given: 582
« Reply #3 on: December 14, 2005, 02:07:23 02:07 »
looks like having trouble i konw you have sent me a pm but cant get it
wizpic
Faros
-Given: 141
-Receive: 178
« Reply #4 on: December 14, 2005, 02:53:35 14:53 »
Hi ...
Please Post your code along with protues design file to be able to help you ... hope you will solve the upload problem soon ....
jeanninemtv
-Given: 57
-Receive: 25
« Reply #5 on: December 15, 2005, 03:48:24 15:48 »
my original code ..
DEVICE 16F84A
DECLARE LCD_DTPIN PORTB.4
DECLARE LCD_RSPIN PORTB.3
DECLARE LCD_ENPIN PORTB.2
DECLARE LCD_LINES 1
'DECLARE FSR_CONTEXT_SAVE = ON
DIM TEMP AS WORD
SYMBOL RELAY PORTB.1
ON_HARDWARE_INTERRUPT ISRA
GOTO NO_INTA
ISRA:
HIGH RELAY
DELAYMS TEMP
LOW RELAY
INTCON.1=0
CONTEXT RESTORE
NO_INTA:
INTCON=$90
TRISB=1
PORTB=0
CLS
'              0000000001111111
'              1234567890123456
GOSUB SCREEN
NADA:
IF PORTA.1=0 THEN
TEMP=TEMP+1
ENDIF
IF PORTA.2=0 THEN
  IF TEMP=0 THEN
  GOTO SHOWME
  ENDIF
TEMP=TEMP-1
ENDIF
SHOWME:
GOSUB LACK
GOTO NADA
SCREEN:
PRINT AT 1,1 ,"TRIG:"
PRINT AT 1,15 ,"ms"
RETURN
LACK:
PRINT AT 1,10,DEC4 TEMP
DELAYMS 100
RETURN
END
i haven-t noted that delayms uses two opr three CALLs ...
that-s why my stack overflows quickly and i return to hell and not on the main loop.
i replaced it with a for   next   ...  with an delayms made in asm ....  to generate N x delayms ))))))
tif you have another suggest share it...
-Given: 582
« Reply #6 on: December 15, 2005, 07:06:14 19:06 »
I shall have a look into your code i can see what you want to do now but you may be better using on interrupt
Because a hardware interrupt may occur at any time, It cannot be fully guaranteed that a SYSTEM variable will not be disturbed while inside the interrupt handler, therefore, the safest way to use a HARDWARE interrupt is to write the code in assembler, or to implement a SOFTWARE interrupt using the  on interrupt directive. This will guarantee that no system variables are being altered.
wizpic
tasosstr
-Given: 96
-Receive: 14
« Reply #7 on: December 15, 2005, 09:21:52 21:21 »
Is it a different
form :
and from :
   On Interrupt
So you can Say :
On interrupt  goto ISRA
'Interrupt routine
Disable
ISRA:
Resume
Enable
Try this and tell me.
Best Regards,
Tasosstr
-Given: 582
« Reply #8 on: December 15, 2005, 09:47:05 21:47 »
jeanninemtv
Device 16F84
Declare LCD_DTPIN
[/color][/size]PORTB.4
Declare LCD_RSPIN [/color][/size]PORTB.3
Declare LCD_ENPIN [/color][/size]PORTB.2
Declare LCD_LINES [/color][/size]1
[/color][/size]Dim TEMP As Word
Symbol
RELAY [/size]PORTB.1
ON_INTERRUPT
GoTo [/b]ISRA
' Assign some Interrupt associated aliases
[/color][/size]Symbol T0IE = [/size]INTCON.5 ' TMR0 Overflow Interrupt Enable
[/color][/size]Symbol T0IF = [/size]INTCON.2 ' TMR0 Overflow Interrupt Flag
[/color][/size]Symbol GIE = [/size]INTCON.7 ' Global Interrupt Enable
[/color][/size]Symbol PS0 = [/size]OPTION_REG.0 ' Prescaler ratio bit-0
[/color][/size]Symbol PS1 = [/size]OPTION_REG.1 ' Prescaler ratio bit-1
[/color][/size]Symbol PS2 = [/size]OPTION_REG.2 ' Prescaler ratio bit-2
[/color][/size]Symbol PSA = [/size]OPTION_REG.3 ' Prescaler Assignment (1=assigned to WDT 0=assigned to oscillator)
[/color][/size]Symbol T0CS = [/size]OPTION_REG.5 ' Timer0 Clock Source Select (0=Internal clock 1=External PORTA.4)
[/color][/size]Symbol LED = [/size]PORTB.1
GoTo NO_INTA [/size]' Jump over the interrupt subroutine
' Interrupt routine starts here
' Initiate the interrupt
[/color][/size]GIE = 0 ' Turn off global interrupts
[/color][/size]PSA = 0 ' Assign the prescaler to external oscillator
[/color][/size]PS0 = 1 ' Set the prescaler
[/color][/size]PS1 = 1 ' to increment TMR0
[/color][/size]PS2 = 1 ' every 256th instruction cycle
[/color][/size]T0CS = 0 ' Assign TMR0 clock to internal source
[/color][/size]TMR0 = 0 ' Clear TMR0 initially
[/color][/size]T0IE = 1 ' Enable TMR0 overflow interrupt
[/color][/size]GIE = 1 ' Enable global interrupts
[/color][/size]GoTo NO_INTA
ISRA:
High RELAY
DelayMS TEMP
Low RELAY
T0IF = [/size]0
Context Restore
NO_INTA:
[/size]INTCON=$90
TRISB=1
PORTB=0
Cls
[/size]' 0000000001111111
' 1234567890123456
[/color][/size]GoSub SCREEN
NADA:
If [/size]PORTA.1=0 Then
TEMP=TEMP+1
EndIf
If
[/size]PORTA.2=0 Then
If
TEMP=[/size]0 Then
GoTo
SHOWME
EndIf
TEMP=TEMP-1
EndIf
SHOWME:
GoSub LACK
GoTo NADA
SCREEN:
Print At [/size]1,1 ,"TRIG:"
Print At [/size]1,15 ,"ms"
Return
LACK:
Print At [/size]1,10,DEC4 TEMP
DelayMS
100
Return
End
Try that it should work if i have understood you i can alter the pules and see it change on scope
Just  let me know if it's ok or not
wizpic
[/size]
picstudent
« Reply #9 on: December 15, 2005, 11:40:43 23:40 »
thanks i-ll try it and then i -ll show my own answer
... rego ... who are are you really ?
picstudent
« Reply #10 on: December 15, 2005, 11:42:03 23:42 »
i have problems with the interrupts too!!!    so i wish to make this on mikrobasic !
-Given: 582
« Reply #11 on: December 16, 2005, 12:08:32 00:08 »
Picstudent
Not sure about mikrobasic they do soem things differently i perfer PDS.
What are you trying to do ?
wizpic
jeanninemtv
-Given: 57
-Receive: 25
« Reply #12 on: December 23, 2005, 02:05:37 02:05 »
thanks, i have replaced delayms on interrupt subroutine with a            for   next and a single asm delay ..
all my troubles fixed
thanks!!
