May 31, 2025, 12:23:59 12:23
Pages: [1] 2  All
Author Topic: Using TRIAC to switch on a mains transformer  (Read 14728 times)
« on: November 15, 2012, 11:43:25 11:43 »
I was thinking about using a TRIAC to switch on a mains transformer that is paralleled by a 47R resistor which is bypassed after 100ms. I am planning to design a softstart circuit to be used with such transformers to prevent the initial surge at power on. Now my questions are, 1. is it OK to use TRIACs, if yes, 2. what is the correct angle at which I should fire the TRIAC to ensure the minimum current surge? 0, 45, 60, 90, etc? 3. How long should I wait to bypass the resistor?
Edit: I found an interesting document that changes thinking a bit. I also am thinking about something like this:
« Last Edit: November 15, 2012, 12:49:20 12:49 by metal » Logged
-Receive: 992
« Reply #1 on: November 15, 2012, 01:17:55 13:17 »
This may share some more lights on the problem
http://www.emeko.de/uploads/media/01-speech-from-berlin-at-cwieme-2004_01.pdf
« Reply #2 on: November 15, 2012, 03:12:57 15:12 »
interesting, it took me quite some time thinking how he ensures the relay is switching correctly. Seems at the 4th magnetizing cycle he switches on both thyristor and relay to ensure there is no delay in relay switching for the following +ve half, is that true!!?? I don't know, is he using a relay after all?
Edit: in p. 16 it is mentioned that relay is activated at the peak of the last magnetization pulse.
« Last Edit: November 15, 2012, 03:29:25 15:29 by metal » Logged
« Reply #3 on: November 15, 2012, 09:51:27 21:51 »
K.I.S.S.
http://www.cantherm.com/products/thermistors/choosing_ntc.html
« Reply #4 on: November 16, 2012, 05:14:04 05:14 »
+1 for thermistor.  we also used to use a relay bypass around the thermistors after the initial charge up of bus caps to improve Max power delivery and allow small thermistors. useful method if you have big power.
« Reply #5 on: November 16, 2012, 09:28:43 09:28 »
frankly, I don't want to use thermistors. Yesterday I was investigating the possibility of using an existing code of a leading edge dimmer that I wrote few months ago to see if I can implement the magnetization pulsing method and then supply full wave. I added few lines of code and ended up with a random magnetization pulse direction (half-wave, no dimming), nevertheless I was still able to see that after three pulses, the third was a complete sine wave, happy ending. I am using a MOSFET in the leading edge dimmer, and I started thinking about reversing some lines in the code to implement a dimmer and see what results I get, any way, I will bypass the semiconductors by a relay, I will post more info later.
zab
-Given: 25
-Receive: 58
« Reply #6 on: November 16, 2012, 11:44:50 11:44 »
The attached doc. require some careful study. For triac based soft start requires switching on the device near 180. then slowly reduce this angle to 120 90 60 so on. But one thing keep in mind that trigger pulse should remain on during the time of conduction. Switching near 0 and 180 is not possible.For voltage  across device is not sufficient to keep it on.The device in this region goes on and off rapidly creating high voltage pulses. a smart snubber is required across the device.
« Reply #7 on: November 16, 2012, 12:25:16 12:25 »
Which document are you referring? if mine, where did you read I should switch on at 180 degrees and why do I have to change the angle this way, it is not mentioned in the document.
There is one thing I could not answer: when is it OK to turn off the transformer?? We were talking about when to turn it on and how, but what about turning it off?
« Last Edit: November 16, 2012, 12:31:50 12:31 by metal » Logged
Atmelfan
« Reply #8 on: November 16, 2012, 01:14:40 13:14 »
Why not use a MOC3041 (Zero crossing optoisolator with triac driver output) which already switches on at the zero crossing point and therefore no problems with surges?
-Receive: 992
« Reply #9 on: November 16, 2012, 01:24:36 13:24 »
There are several disadvantageous conditions then using both resistors and NTCs.
Posted on: November 16, 2012, 02:20:51 14:20 - Automerged
No switching at zero crossing point give huge surges in transformers. That is shown in the document in post 1
« Reply #10 on: November 16, 2012, 02:10:10 14:10 »
Here is a snapshot of what I was talking about yesterday, I mentioned it was an experimental change in an existing code, hence, the pulsing direction is random, at least, it is possible to test the idea in no time. But I am still thinking when I should turn it off, also what to use, if I use a TRIAC and then bridge it by a relay, it will be the best choice, provided that even with a TRIAC trigger should always stay ON during each half-wave time so that the current can flow correctly. At turn off, I still can turn the TRIAC on and take the relay out to control the turn off, but if the turn off requirements don't match how a TRIAC worked, this will be a problem and I will have to change the semiconductor device, I don't know yet.
« Last Edit: November 16, 2012, 02:12:39 14:12 by metal » Logged
« Reply #11 on: November 16, 2012, 09:51:56 21:51 »
I thought that I grabbed the idea, but apparently no I did not, there are many other issues to take care of in order to make this technique successful. I was looking at the documents on emeko site, and found this and this.
The guy doesn't give the transformer a complete half-wave, rather he gives it a part of it at 130 degrees which is equal to 237V, it seems that he measure the current according to this document to find out when is the right moment to turn the full power on. Moreover, the pulse width is variable depending on the measured current, and also the device he makes has a short-circuit protection and according to this document he solved the voltage dipping issues!
There are many pieces missing on how things are done with the minimal components count and the procedure to do them correctly to make this technique completely work. I don't know how to measure the current as he does, and I also don't know how he detects when it is the right moment to switch power on, add to it I don't know how he detects a missing half-wave and then waits the next half-wave to pass and then turns power back on. Really interesting....!
« Last Edit: November 17, 2012, 01:18:56 01:18 by metal » Logged
« Reply #12 on: November 16, 2012, 10:49:26 22:49 »
We used to have issues with soft start of transformers when we custom designed large AC toroid stepdowns (5KW 208 to 10V).  Because the peak flux of the transformers was designed to be low, and because we were using iron powder core the risidual flux was pretty high so if we started to deliver power on the same polarity half wave as the thing turned off we'd get a core saturation event which blew breakers.
It was hard to fix.  We used slow ramp up phase angle firing which looks similar to your documents.  One of the biggest problems we had was any phase lead/lag would wreak havoc as the controllers we used didn't monitor both current and voltage so you could easily miss fire if for instance the transformer happened to be unloaded.
It's one of the reasons that Solutions and I were keen on the NTC approach.  It's not elegant (and engineers love cool and elegant) but it does the job.
We used controllers from HB Controls.  They had to build some custom firmware for us with a lot of back and forth before we got our system working right (and by right I mean well enough to make the customer happy, far from perfect though).
Posted on: November 16, 2012, 11:44:30 23:44 - Automerged
Turn off only matters if you care where the residual flux is left on the transformer, or if you have a leaky transformer and you need to shunt the primary magnetizing current.  I'm assuming you have a tightly coupled transformer.  Now, as I mentioned if you turn off at the top of a half wave and turn on during the same polarity cycle you can drive your core flux to 2x.  This might be fine if you have a lot of flux density margin (and you can get transformers designed for phase angle firing for this issue with higher flux density).
So, the turn off depends.  If you can turn off at zero, then your turn on phase doesn't matter as much.  It's a little bit of an application specific question.
« Reply #13 on: November 17, 2012, 01:01:00 01:01 »
Thanks for providing this info, it seems that large companies are working on such issues, this makes me think twice about working on such an issue as an individual. May be if I combine the solution in the document attached in the first post with NTC, or even resistors, things would be acceptable for a home appliance, I think this is better than creating an extremely complicated system that needs adjusting.
The thing that makes me revert is that I must monitor the wave and in case of a missing halfwave I will have to correctly recover, otherwise my system is useless. I will think more about it and read more to see what can be done. What I was thinking is completely wrong about providing complete halfwaves, they should be 237V instead of 310V which occurs at 130 degrees. If I figure some way to monitor the halfwave polarity and to track the last polarity before a power dip, then I will continue with emeko solution.
« Last Edit: November 17, 2012, 01:50:37 01:50 by metal » Logged
« Reply #14 on: November 19, 2012, 07:52:32 07:52 »
I found HCPL3700 opto-coupler to be a good candidate, this one has all necessary parts except the resistor. I am willing to use two zener diodes connected back to back in order to limit the voltage into the opto-coupler, also how should I calculate the resistor, based on RMS or peak voltage?
« Reply #15 on: November 23, 2012, 09:21:18 21:21 »
I finally have got time to show something, the uploaded file includes a simulation video, proteus+hex files.
« Reply #16 on: November 25, 2012, 10:55:37 10:55 »
Here is the zero-crossing detector part done yesterday. I will put this part inside a heatshrink, the rest will be isolated from mains.
still more to follow.
I better move this thread to projects section, may be later.
« Last Edit: November 25, 2012, 10:58:02 10:58 by metal » Logged
Toxible
« Reply #17 on: November 25, 2012, 03:17:02 15:17 »
"switch on a mains transformer that is paralleled by a 47R" ?
The resistor is in parallel?
BTW, I think that is not very useful to do a softstart for a transformer!
A transformer primary is a simple inductor, so current is (ideally) shifted 90° compared to voltage phase. Why use a softstart?
sarah90
« Reply #18 on: November 25, 2012, 03:30:38 15:30 »
The soft start is not for the transformer, it is for the capacitors in the power supply.
Toxible
« Reply #19 on: November 25, 2012, 04:01:49 16:01 »
Ok so we need to switch on the power on the zero crossing right?
The circuit posted has a little error:
Vin max = 230Vrms So the peak value is 230 * sqrt(2) = 325V
(325V - 1,4V) * 22k / (22k+220k+220k) = 15,4V... C1 must be 16V (25 is best)...
But i see another little error. C1 will charge through R1 + R2 and it discharge through R3 (of course Vbe of Q1). Is better to add a resistor on Q1 base.
« Reply #20 on: November 25, 2012, 04:19:15 16:19 »
Don't bother, I meant the 47R in series with the transformer, not parallel, I don't know what was on my mind when I wrote "parallel".. I will draw a schematic to make things clearer..
I will try the ZCD circuit as is today, if problems occur, I will change it. But, I don't understand how it will discharge through Vbe junction, why would it do that any way while D5 should prevent that.
Toxible
« Reply #21 on: November 25, 2012, 04:55:11 16:55 »
Well well welll.... I've do a mistake... now i will make order on my ideas..
So, suppose C1 at 10V. now when Vin is approx zero, D1, D2, D3, D4 are off and so remove this form your mind. current can come out from C1 (+) and go through R3, go on Q1 base and reach C1 again (-).. so C1 will discharge. Q1 is a NPN bjt so you can see this as two diodes. But we are lucky twice:
1- C1 will not reach more of 4V, infact when Q1 goes on C1 can discharge throught R4. if you do some math you can see that this.
2- Discharge throught R3 is very short and will not make any problem.
Sorry for the mistake... my mind is a bit fused Smiley
« Reply #22 on: November 25, 2012, 04:58:11 16:58 »
You aren't really understanding how a real transformer works.  It isn't an inductor.  It does have parasitic magnetizing inductance but in the case of a "good" transformer that inductance is very small.
If the transformer has good coupling then to the line, the transformer looks like a reflection of the load multiplied or divided by the turns ratio (depending on how you reference things).
The inductance of the transformer has very little impact on whether you would want a soft start.  The load is the main determining factor.
The second factor you are missing is the saturation flux of the transformer which, when reached, will turn the transformer into a short circuit.  If you read the whole thread you will see some explanation and examples of this.
sarah90
« Reply #23 on: November 25, 2012, 06:03:54 18:03 »
Dear Toxible, it does look like to me that you are copying messages and posting not so useful information when looking at your first 6 posts. In your invite you said you wanted another chance to contribute, but I don't think this way it is helping the forum.
« Reply #24 on: November 25, 2012, 09:02:24 21:02 »
Neither Q1 BE junction nor R3 will not be able to discharge C1 because of D5. Your assumptions are incorrect, rest your soul and think before you write something down, because I spent quite sometime analyzing the circuit, thu I did in the past, but you did confuse me.
Posted on: November 25, 2012, 11:55:56 23:55 - Automerged
There are moderators on the forum for that job, and there is a report button in case you felt inconvenient with a post/member, moderators then can decide what to do.
Pages: [1] 2  All
