You think I am funny guy huh?
January 23, 2018, 12:59:13 00:59
Author Topic: QEI modules and high resolution encoders.  (Read 2124 times)
RaynW
-Receive: 12
« on: September 06, 2012, 11:34:06 23:34 »
I want to share with you some piece of code Ive been working on, in hope it will be useful.
The problem arises when using high resolution encoders with 16bit Quadrature Encoder Modules (QEI). They only count to 2^16 wich is pretty low for a 1024 pulses/rev encoder geared through 1:40 transmission. You have 1024*4*25 = 163840 pulses/rev.
The trick is:
1.- Get the velocity first (or position increment/decrement), from a periodic tick interrupt (the same interrupt you would use to sample the axis position; motion controllers Ive been working with used 250ms). Here you configure the QEI module to 2^16 modulo no matter your axis modulo. This will work provided the encoder module doesnt count 2^15 or more pulses in the same direction, between two consecutive ticks; or you will lose the wright direction of rotation. You can refer to te following appnote to know how to get the velocity properly. http://ww1.microchip.com/downloads/en/DeviceDoc/93002A.pdf
2.- Then integrate this velocity over a 32bit counter by software.
3.- If you are working with a rotary axis, it has some unwind or modulo value. It is the number of pulses it counts to reach the same position. The 32bit counter must be adjusted by the unwind value before used by the sampling routine.
4.- If working with linear axis, theres no need of step 3.
Here the code:
/* #includes here */
/* Used to get the shortest path on a rotary (cyclic) dimension - Refer to appnote for an explanation */
long shortest_path(long path, long unwind)
long h_unwind;
h_unwind = unwind / 2; /* Half the axis unwind */
if (path >= 0) {
if (path >= h_unwind)
path -= unwind;
else {
if (path < (-h_unwind))
path += unwind;
return path;
/* Servo tick - aproximately 250 us */
void __attribute__((interrupt, auto_psv)) _T2Interrupt(void)
volatile struct T_axis {
unsigned long pos;
unsigned long unwind;
int vel;
} master;
static unsigned raw_pos_m[2];
/* Samples encoder module - POS2CNT */
raw_pos_m[1] = ReadQEI2();
/* Calculates velocity - or position increment/decrement */
master.vel = (int)shortest_path((long)raw_pos_m[1] - raw_pos_m[0], POSXCNT_MAX);
raw_pos_m[0] = raw_pos_m[1];
/* Integrates velocity and calculates position */
master.pos += master.vel;
/* Unwinds if necessary */
if (master.pos >= master.unwind) {
if (master.vel >= 0)
master.pos -= master.unwind;
else
master.pos += master.unwind;
/* master.pos IS ACTUALLY THE POSITION YOU WANT. You can use it from now on. */
IFS0bits.T2IF = 0;
int main(void)
/* Modules, Interrupts, IO ports config not shown, but would go here */
master.unwind = 40960; /* Used 1024 PPR encoder with 1:10 gear ratio, so 1024*4*10 = 40960 */
/* Main loop */
while (1) {
ClrWdt();
return 0;
I really hope you find this code useful. Perhaps something is unclear. Please feel free to criticize.
-Receive: 387
« Reply #1 on: September 07, 2012, 01:11:58 01:11 »
That's a good one, but I think it will be easier and simpler using QEI interrupt.
Maintain one 16 bit variable as high value together with 16 bit QEI counter as low value to represent a 32 bit counter register. On QEI overflow increment the variable, and decrement it on QEI underflow.
RaynW
-Receive: 12
« Reply #2 on: September 07, 2012, 01:52:47 01:52 »
Mmm Im thinking now. Suppose you need to count to 65537.
1.- interrupt on 65535. and increment 16bit high counter.
2.- must change qei module target to 65537-65535 = 2 so next interrupt is on 2.
3.- must change target again to interrupt on 65535. So must change interrupt condition for every interrupt call.
Besides, this application doesnt need to interrupt on a specified position. When you need that then I think qei counter alone (and its interrupt are the only way). Here we only need to read axis position at a periodic rate to control the motor driver.
