« on: June 29, 2012, 12:20:40 00:20 » |
XC32 Compilers Discussion Topic
8bitMCU
-Given: 6
-Receive: 19
« Reply #1 on: August 10, 2012, 11:39:48 23:39 » |
MPLAB xc32 v1.10 has been release http://www.microchip.com/mplabxc32windowsNew Features in MPLAB® XC32 v1.10 Support for C++ Standard C++ Library
marcodassi
-Given: 73
-Receive: 26
« Reply #2 on: August 12, 2012, 11:10:48 11:10 » |
Just downloaded XC8, XC16 and XC32 1.10; tested with current fix; results: - XC8 1.10 - fine, works in Pro mode with all optimizations; - XC16 1.10 - fine, works in Pro mode with all optimizations; - XC32 1.10 - DOESN'T WORK - the compiler stays in Free mode, no optimizations allowed I've tried to copy xclm.exe in the "\Program Files\Microchip\xc32\v1.10\bin" folder too, with no luck. Please fix it, if possibile  Thank you very much in advance!
Top
-Given: 53
-Receive: 1719
« Reply #3 on: August 13, 2012, 07:20:55 19:20 » |
Fix updated; see http://www.sonsivri.to/forum/index.php?topic=44014.0
marcodassi
-Given: 73
-Receive: 26
« Reply #4 on: October 05, 2012, 10:50:54 10:50 » |
XC32 1.11 is out! testing now... update: latest "medicine" seems to work
« Last Edit: October 05, 2012, 11:02:52 11:02 by marcodassi »
tomywong
-Given: 103
-Receive: 213
« Reply #5 on: October 26, 2012, 03:01:26 03:01 » |
marcodassi
-Given: 73
-Receive: 26
« Reply #6 on: October 26, 2012, 11:32:17 11:32 » |
latest "medicine" seems to work on this update too
respected
« Reply #7 on: November 28, 2012, 12:07:07 12:07 » |
This medicine is *.c file but it doesn't work *.cpp file. Microchip released cpp license file at web page.
Manuel
-Given: 712
-Receive: 194
« Reply #8 on: December 11, 2012, 09:28:29 21:28 » |
PaulC
-Given: 3935
information is free and should be shared for free
« Reply #9 on: February 06, 2013, 07:44:43 19:44 » |
Microchip's Free MPLAB® XC32++ Compiler for all 32-bit PIC32 MCUs offers unlimited code generation Key Facts: Free C++ Compiler enables maximum code re-use Standards compliant for commercial applications Includes Dinkumware® Libraries and has no time or memory limits Supports all Microchip 32-bit PIC32 microcontrollers Workstation and network server licenses are also available for best-in-class optimisations Microchip has announced its free C++ compiler with unlimited code generation: The Free MPLAB® XC32++ Compiler supports all of Microchip’s 32-bit PIC32 microcontrollers (MCUs). This compiler enables designers to develop and re-use C++ projects by making all of Microchip’s C language extensions available in an environment that is compliant with the majority of C++98 and C++2003 ANSI standards. Additionally, the Free MPLAB XC32++ Compiler includes Dinkumware® standard C, C++, and template libraries. The Free version of the MPLAB XC32++ Compiler is available for download now; has no time or memory limits; and can be used in a broad range of commercial applications, from industrial to academic environments. For users who demand best-in-class optimisations or a network server license, the MPLAB XC32++ PRO Workstation License (SW006023-3), and the MPLAB XC32++ PRO Network Server License (SW006023-3N), are also available. Existing licensees of Microchip’s MPLAB XC32 compilers can add the XC32++ option with a workstation or network-server license. For more information, or to download the Free version of the MPLAB XC32++ Compiler, visit Microchip’s Web site at http://www.microchip.com/get/10E7. The MPLAB XC32++ PRO Workstation License and MPLAB XC32++ PRO Network Server License are available at: http://www.microchip.com/get/R7TC
find it , read it , share it .
8bitMCU
-Given: 6
-Receive: 19
« Reply #10 on: May 02, 2013, 11:01:18 11:01 » |
marcodassi
-Given: 73
-Receive: 26
« Reply #11 on: May 02, 2013, 03:52:30 15:52 » |
seems to work  BTW, no major improvements in 1.21... "only" new parts, header & linker scripts updates
Catcatcat
-Given: 289
-Receive: 1749
« Reply #12 on: October 30, 2013, 04:08:37 16:08 » |
released a new version Windows (x86/x64) MPLAB® XC32 Compiler v1.22
Manuel
-Given: 712
-Receive: 194
« Reply #13 on: November 14, 2013, 03:30:09 15:30 » |
FYI: released a new version Windows (x86/x64) MPLAB® XC32 Compiler v1.30
Manuel.
marcodassi
-Given: 73
-Receive: 26
« Reply #14 on: November 14, 2013, 04:49:08 16:49 » |
Manuel: Thank you, but: where is it?  edit: found! on the mchip site (but is still listed as 1.22)
Catcatcat
-Given: 289
-Receive: 1749
« Reply #15 on: November 14, 2013, 06:25:04 18:25 » |
Do not believe what is written, and just click and you will be happy
Catcatcat
-Given: 289
-Receive: 1749
« Reply #16 on: January 10, 2014, 12:32:55 12:32 » |
Manuel
-Given: 712
-Receive: 194
« Reply #17 on: June 03, 2014, 11:36:23 11:36 » |
FYI: released a new version Windows (x86/x64) MPLAB® XC32 Compiler v1.32
'njoy
Manuel.
marcodassi67
Warned
« Reply #18 on: June 16, 2014, 02:55:26 14:55 » |
They check for modified xclm file as is in latest XC32 release.
hello petarp, you mean latest xclm doesn't work with XC32? I've tried it some time ago and it seems working,,,
petarp
-Receive: 51
« Reply #19 on: June 16, 2014, 04:16:50 16:16 » |
Hi marcodassi67, Yes XC32 v1.32 checks for modified "xclm" file. Here is the fix for XC32: 1. Open "C:\Program Files\Microchip\xc32\v1.32\bin\bin\gcc\pic32mx\4.5.2\cc1.exe" file with hex editor. 2. Find these bytes "75 6a 89 5d" and replace first two bytes with "90" ("90 90 89 5d"). 3. Do same with "C:\Program Files\Microchip\xc32\v1.32\bin\bin\gcc\pic32mx\4.5.2\cc1plus.exe" and "C:\Program Files\Microchip\xc32\v1.32\bin\bin\gcc\pic32mx\4.5.2\lto1.exe" files. 4. And use latest "xclm" file from here. It works for C++ too.
Regards.
Wannabe
-Given: 228
-Receive: 285
« Reply #20 on: June 16, 2014, 05:17:53 17:17 » |
Regards.
And here is the patcher for XC32. Great work, petarp  I guess there's only a matter of time before XC16 needs the same treatment...
« Last Edit: June 16, 2014, 05:20:20 17:20 by Wannabe »
juvann
-Receive: 61
« Reply #21 on: July 13, 2014, 03:16:16 15:16 » |
Now xc32 calculate the sha256sum of file xclm. In linux version the sum of origina xclm is 4fae1d53570ebffe637d8c5f77789ecbe690f67af65d0e3af8474bfee479239e with a perl command with can replace it with new sum sha256sum /opt/microchip/xc32/v1.32/bin/xclm perl -pi -e 's/4fae1d53570ebffe637d8c5f77789ecbe690f67af65d0e3af8474bfee479239e/NEW VALUE OF SHA256SUM/g' /opt/microchip/xc32/v1.32/bin/bin/gcc/pic32mx/4.5.2/cc1 perl -pi -e 's/4fae1d53570ebffe637d8c5f77789ecbe690f67af65d0e3af8474bfee479239e/NEW VALUE OF SHA256SUM/g' /opt/microchip/xc32/v1.32/bin/bin/gcc/pic32mx/4.5.2/cc1plus
Catcatcat
-Given: 289
-Receive: 1749
« Reply #22 on: August 14, 2014, 04:17:05 16:17 » |
« Last Edit: December 12, 2014, 10:04:48 10:04 by Catcatcat »
frnando
-Given: 10
« Reply #23 on: November 10, 2014, 09:55:38 21:55 » |
Sorry, but the patcher/xclm is still working with v1.33? Thanks.
bluex
-Given: 10
-Receive: 39
« Reply #24 on: December 26, 2014, 11:22:25 23:22 » |
