October 16, 2025, 07:21:07 19:21
Author Topic: Micro PWM module with atmega 88p  (Read 5387 times)
blue_17
-Receive: 41
« on: May 12, 2012, 04:02:59 16:02 »
Hi this is my first project with avr
http://www.blue17.elektroda.eu/moje-projekty
The main purpose of making this construction was to create a device that uses PWM.
The set consists of:
    programming connector
    4 LEDs
    4 buttons
    temperature sensor DS18B20 on 1-wire bus
    connectors for engines/fans
    power connector protected by diode against power reverse connection
The kit works with programmer USBasp on Linux as well as Windows.
Files for PCB can be downloaded from:
http://www.blue17.elektroda.eu/download/projekty-2 file "Mikro zestaw uruchomieniowy''
Regards all
alfonsoagama
-Given: 39
-Receive: 40
« Reply #1 on: May 17, 2012, 04:37:45 16:37 »
But the Max Current is 1A for the diode 1N4001
blue_17
-Receive: 41
« Reply #2 on: May 27, 2012, 11:20:02 23:20 »
Max current for one fun is 120 mA
Diode 1N4007 is example part
Mosfets would be low voltage version for example IRF8714
